Example MPC5744P PinToggleStationery S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* initializes interrupts, blinking one LED by interrupt,
* initializes and display notice via UART terminal and then terminals ECHO.
* Test HW:        X-MPC5744PE257DC, MPC57xx motherboard
* MCU:              PPC5744PFMMM8 1N65H
* Terminal:        19200-8-no parity-1 stop bit-no flow control on LINFlexD_0
* Fsys:             200 MHz
* Debugger:      Lauterbach Trace32
*                       PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  User LED 1 connected to A0 (P8.0),
Comments
Hi   b55689​
I think that this code should be fixed "Uart.h".....for example like "sys\uart.h"....
Please check this code..
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1106644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5744P%20PinToggleStationery%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20initializes%20interrupts%2C%20blinking%20one%20LED%20by%20interrupt%2C%3C%2FP%3E%3CP%3E*%20initializes%20and%20display%20notice%20via%20UART%20terminal%20and%20then%20terminals%20ECHO.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20X-MPC5744PE257DC%2C%20MPC57xx%20motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5744PFMMM8%201N65H%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20LINFlexD_0%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20200%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20User%20LED%201%20connected%20to%20A0%20(P8.0)%2C%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1106644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20initializes%20interrupts%2C%20blinking%20one%20LED%20by%20interrupt%2C%3C%2FP%3E%3CP%3E*%20initializes%20and%20display%20notice%20via%20UART%20terminal%20and%20then%20terminals%20ECHO.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20X-MPC5744PE257DC%2C%20MPC57xx%20motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5744PFMMM8%201N65H%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20LINFlexD_0%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20200%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20User%20LED%201%20connected%20to%20A0%20(P8.0)%2C%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5744P%20PinToggleStationery%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%26nbsp%3B%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fb55689%22%20target%3D%22_blank%22%3Eb55689%3C%2FA%3E%E2%80%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20think%20that%20this%20code%20should%20be%20fixed%20%22Uart.h%22.....for%20example%20like%20%22sys%5Cuart.h%22....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20check%20this%20code..%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎01-05-2016 07:36 AM
Updated by:
