Example MPC5744P 1b+2b_RAM_ECC_error_injection GHS714
* Detailed Description:
* Purpose of the example is to show how to generate Multi-bit or Single-bit ECC
* error in internal RAM (user must choose it in the option at the end of main
* function).
* ECC fault is generated with using of core register E2EECSR. If error injection
* is enabled (E2EECSR0[INVC]=1) and certain mask is set (E2EECSR0[CHKINVT]),
* subsequent write to SRAM creates error in SRAM array.
* When corrupted data is read the IVOR1 exception handler is called in case of
* multi-bit ECC error (IVOR1 exception occurs) and FCCU_Alarm_Interrupt handler
* is called in case of single-bit ECC error (FCCU interrupt occurs).
* Both function calls MEMU handler.
* The example displays notices in the terminal window (connector J19 on
* MPC57xx_Motherboard)(19200-8-no parity-1 stop bit-no flow control on eSCI_A).
* No other external connection is required.
* Test HW:         MPC57xx_Motherboard + MPC5744P-144DC
* MCU:             PPC5744PFMLQ8,0N15P,QQAA1515N, Rev2.1B
* Fsys:            200 MHz PLL with 40 MHz crystal reference
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH, RAM
* Terminal:        19200-8-no parity-1 stop bit-no flow control
* EVB connection:  default
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1117504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5744P%201b%2B2b_RAM_ECC_error_injection%20GHS714%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E7%9A%84%E7%9B%AE%E7%9A%84%E6%98%AF%E5%B1%95%E7%A4%BA%E5%A6%82%E4%BD%95%E7%94%9F%E6%88%90%E5%A4%9A%E4%BD%8D%E6%88%96%E5%8D%95%E4%BD%8D%20ECC%3CBR%20%2F%3E%20*%20%E5%86%85%E9%83%A8%20RAM%20%E9%94%99%E8%AF%AF%EF%BC%88%E7%94%A8%E6%88%B7%E5%BF%85%E9%A1%BB%E5%9C%A8%E4%B8%BB%E7%A8%8B%E5%BA%8F%E6%9C%AB%E5%B0%BE%E7%9A%84%E9%80%89%E9%A1%B9%E4%B8%AD%E9%80%89%E6%8B%A9%E5%AE%83%3CBR%20%2F%3E*%20%E5%8A%9F%E8%83%BD%EF%BC%89%E3%80%82%3CBR%20%2F%3E*%20%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%20E2EECSR%20%E4%BC%9A%E4%BA%A7%E7%94%9F%20ECC%20%E6%95%85%E9%9A%9C%E3%80%82%E5%A6%82%E6%9E%9C%E9%94%99%E8%AF%AF%E6%B3%A8%E5%85%A5%3CBR%20%2F%3E*%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%88E2EECSR0%5BINVC%5D%3D1%EF%BC%89%E5%B9%B6%E4%B8%94%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%9F%90%E4%BA%9B%E6%8E%A9%E7%A0%81%EF%BC%88E2EECSR0%5BCHKINVT%5D%EF%BC%89%EF%BC%8C%3CBR%20%2F%3E%20*%20%E9%9A%8F%E5%90%8E%E5%86%99%E5%85%A5%20SRAM%20%E4%BC%9A%E5%9C%A8%20SRAM%20%E9%98%B5%E5%88%97%E4%B8%AD%E4%BA%A7%E7%94%9F%E9%94%99%E8%AF%AF%E3%80%82%3CBR%20%2F%3E*%20%E5%BD%93%E8%AF%BB%E5%8F%96%E6%8D%9F%E5%9D%8F%E7%9A%84%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%8C%E5%88%99%E4%BC%9A%E8%B0%83%E7%94%A8%20IVOR1%20%E5%BC%82%E5%B8%B8%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E*%20%E5%A4%9A%E4%BD%8D%20ECC%20%E9%94%99%E8%AF%AF%EF%BC%88%E5%8F%91%E7%94%9F%20IVOR1%20%E5%BC%82%E5%B8%B8%EF%BC%89%E5%92%8C%20FCCU_Alarm_Interrupt%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E*%20%E5%9C%A8%E5%8F%91%E7%94%9F%E5%8D%95%E4%BD%8D%20ECC%20%E9%94%99%E8%AF%AF%EF%BC%88%E5%8F%91%E7%94%9F%20FCCU%20%E4%B8%AD%E6%96%AD%EF%BC%89%E6%97%B6%E8%B0%83%E7%94%A8%E3%80%82%3CBR%20%2F%3E*%20%E4%B8%A4%E4%B8%AA%E5%87%BD%E6%95%B0%E9%83%BD%E8%B0%83%E7%94%A8%20MEMU%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%9C%A8%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%99%A8%20J19%20%E4%B8%8A%EF%BC%89%E6%98%BE%E7%A4%BA%E9%80%9A%E7%9F%A5%3CBR%20%2F%3E*%20MPC57xx_Motherboard)(19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6)%E3%80%82%3CBR%20%2F%3E*%20%E6%97%A0%E9%9C%80%E5%85%B6%E4%BB%96%E5%A4%96%E9%83%A8%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3E*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC57xx_%E4%B8%BB%E6%9D%BF%20%2B%20MPC5744P-144DC%3CBR%20%2F%3E%20*%20MCU%EF%BC%9APPC5744PFMLQ8%2C0N15P%2CQQAA1515N%EF%BC%8CRev2.1B%3CBR%20%2F%3E%20*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3CBR%20%2F%3E*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%EF%BC%8CRAM%3CBR%20%2F%3E%20*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%E5%81%9C%E6%AD%A2%E4%BD%8D-%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1117504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E%20*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3E%20*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E7%9A%84%E7%9B%AE%E7%9A%84%E6%98%AF%E5%B1%95%E7%A4%BA%E5%A6%82%E4%BD%95%E7%94%9F%E6%88%90%E5%A4%9A%E4%BD%8D%E6%88%96%E5%8D%95%E4%BD%8D%20ECC%3CBR%20%2F%3E%20*%20%E5%86%85%E9%83%A8%20RAM%20%E9%94%99%E8%AF%AF%EF%BC%88%E7%94%A8%E6%88%B7%E5%BF%85%E9%A1%BB%E5%9C%A8%E4%B8%BB%E7%A8%8B%E5%BA%8F%E6%9C%AB%E5%B0%BE%E7%9A%84%E9%80%89%E9%A1%B9%E4%B8%AD%E9%80%89%E6%8B%A9%E5%AE%83%3CBR%20%2F%3E*%20%E5%8A%9F%E8%83%BD%EF%BC%89%E3%80%82%3CBR%20%2F%3E*%20%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%20E2EECSR%20%E4%BC%9A%E4%BA%A7%E7%94%9F%20ECC%20%E6%95%85%E9%9A%9C%E3%80%82%E5%A6%82%E6%9E%9C%E9%94%99%E8%AF%AF%E6%B3%A8%E5%85%A5%3CBR%20%2F%3E*%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%88E2EECSR0%5BINVC%5D%3D1%EF%BC%89%E5%B9%B6%E4%B8%94%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%9F%90%E4%BA%9B%E6%8E%A9%E7%A0%81%EF%BC%88E2EECSR0%5BCHKINVT%5D%EF%BC%89%EF%BC%8C%3CBR%20%2F%3E%20*%20%E9%9A%8F%E5%90%8E%E5%86%99%E5%85%A5%20SRAM%20%E4%BC%9A%E5%9C%A8%20SRAM%20%E9%98%B5%E5%88%97%E4%B8%AD%E4%BA%A7%E7%94%9F%E9%94%99%E8%AF%AF%E3%80%82%3CBR%20%2F%3E*%20%E5%BD%93%E8%AF%BB%E5%8F%96%E6%8D%9F%E5%9D%8F%E7%9A%84%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%EF%BC%8C%E5%88%99%E4%BC%9A%E8%B0%83%E7%94%A8%20IVOR1%20%E5%BC%82%E5%B8%B8%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E*%20%E5%A4%9A%E4%BD%8D%20ECC%20%E9%94%99%E8%AF%AF%EF%BC%88%E5%8F%91%E7%94%9F%20IVOR1%20%E5%BC%82%E5%B8%B8%EF%BC%89%E5%92%8C%20FCCU_Alarm_Interrupt%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E*%20%E5%9C%A8%E5%8F%91%E7%94%9F%E5%8D%95%E4%BD%8D%20ECC%20%E9%94%99%E8%AF%AF%EF%BC%88%E5%8F%91%E7%94%9F%20FCCU%20%E4%B8%AD%E6%96%AD%EF%BC%89%E6%97%B6%E8%B0%83%E7%94%A8%E3%80%82%3CBR%20%2F%3E*%20%E4%B8%A4%E4%B8%AA%E5%87%BD%E6%95%B0%E9%83%BD%E8%B0%83%E7%94%A8%20MEMU%20%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%9C%A8%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%99%A8%20J19%20%E4%B8%8A%EF%BC%89%E6%98%BE%E7%A4%BA%E9%80%9A%E7%9F%A5%3CBR%20%2F%3E*%20MPC57xx_Motherboard)(19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6)%E3%80%82%3CBR%20%2F%3E*%20%E6%97%A0%E9%9C%80%E5%85%B6%E4%BB%96%E5%A4%96%E9%83%A8%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3E*%20----------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC57xx_%E4%B8%BB%E6%9D%BF%20%2B%20MPC5744P-144DC%3CBR%20%2F%3E%20*%20MCU%EF%BC%9APPC5744PFMLQ8%2C0N15P%2CQQAA1515N%EF%BC%8CRev2.1B%3CBR%20%2F%3E%20*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3CBR%20%2F%3E*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9ALauterbach%20Trace32%3CBR%20%2F%3E%20*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%EF%BC%8CRAM%3CBR%20%2F%3E%20*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%E5%81%9C%E6%AD%A2%E4%BD%8D-%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3CBR%20%2F%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%E9%BB%98%E8%AE%A4%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E
无评分
版本历史
最后更新:
‎02-20-2021 06:36 AM
更新人:
