Example MPC5607B SRAM_keep_data_over_SW_reset CW210
* File main.c
* Owner David Tosenovjan
* Version 0.1
* Date May-31-2023
* Classification General Business Information
* Detailed Description:
* The purpose of this example is show how to keep data in SRAM memory over SW
* reset.
* INIT_Derivative (file MPC5607B_HWInit.c) is modified to skip ECC RAM
* initialization for SW reset source. Linker command file defines my_ram
* section, a data being kept over reset are accesses as address pointer to this
* location. After initialization SW resets are periodically triggered,
* incrementing data on address test_address_3.
* Test HW: XPC5607B 176LQFP, XPC56XX EVB MOTHEBOARD Rev.C
* MCU: PPC5607BMLUAM03Y
* Terminal: 19200-8-no parity-1 stop bit-no flow control on LINFLEX_0
* Fsys: 64/48 MHz
* Debugger: Lauterbach Trace32
* PeMicro USB-ML-PPCNEXUS
* Target: RAM, internal_FLASH
* EVB connection: none
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1660831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5607B%20SRAM_keep_data_over_SW_reset%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1660831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CPRE%20translate%3D%22no%22%3E********************************************************************************%3CBR%20%2F%3E*%20File%20main.c%3CBR%20%2F%3E*%20Owner%20David%20Tosenovjan%3CBR%20%2F%3E*%20Version%200.1%3CBR%20%2F%3E*%20Date%20May-31-2023%3CBR%20%2F%3E*%20Classification%20General%20Business%20Information%3CBR%20%2F%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20The%20purpose%20of%20this%20example%20is%20show%20how%20to%20keep%20data%20in%20SRAM%20memory%20over%20SW%3CBR%20%2F%3E*%20reset.%20%3CBR%20%2F%3E*%20INIT_Derivative%20(file%20MPC5607B_HWInit.c)%20is%20modified%20to%20skip%20ECC%20RAM%20%3CBR%20%2F%3E*%20initialization%20for%20SW%20reset%20source.%20Linker%20command%20file%20defines%20my_ram%3CBR%20%2F%3E*%20section%2C%20a%20data%20being%20kept%20over%20reset%20are%20accesses%20as%20address%20pointer%20to%20this%3CBR%20%2F%3E*%20location.%20After%20initialization%20SW%20resets%20are%20periodically%20triggered%2C%20%3CBR%20%2F%3E*%20incrementing%20data%20on%20address%20test_address_3.%20%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%20XPC5607B%20176LQFP%2C%20XPC56XX%20EVB%20MOTHEBOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%20PPC5607BMLUAM03Y%3CBR%20%2F%3E*%20Terminal%3A%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20LINFLEX_0%3CBR%20%2F%3E*%20Fsys%3A%2064%2F48%20MHz%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%20none%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%0A%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-31-2023 06:22 AM
更新者:
