Please find attached the document with the prerequisite information for this MCX W71 Training.
if you are having trouble with the MCU-Link debugger or flashing the code from the IDE, please make sure that you are using the latest version.
here the step-by-step instructions to how update the MCU-Link firmware:
Updating MCU-Link firmware using firmware update utility (nxp.com)
After run this command: pip install -U spsdk
I encountered an error. Please advise.
you need to install C++ x64/x86 build tools and Windows SDK as indicated in this link
below is the detail talking about the issue
please follow the suggestion there
