imx8MP swupdate inquiry (how to get ext4 image)
4,017件の閲覧回数
kiyoung
My environment is as follows.
i.MX Linux Yocto Project BSP 6.1.22_2.0.0 Release
NXP i.MX 8MPlus EVK (imx8mpevk)
To use swupdate for imx8MP, refer to SWUpdate OTA i.MX8MM EVK_rev3.pdf.
In the contents of "Image Assembling", there is the following:
06-imx-image-multimedia --> ../slota/imx-image-multimedia-imx8mmevk.ext4
There is no image in ext4 format in the output of bitbake. (There are wic.zst and tar.zst)
How can I get an image in ext4 format? Alternatively, can we proceed with “Image Assembling” using wic.zst?
3,954件の閲覧回数
Rita_Wang
You can refer to the document
4 返答(返信)
3,989件の閲覧回数
Rita_Wang
Yes, you can use it, no problem.
3,973件の閲覧回数
kiyoung
Thank you for your reply
I made the below.
06-imx-image-multimedia -> ../slota/imx-image-multimedia-imx8mp-lpddr4-evk.wic.zst
And, according to the contents of readme.txt, I executed the following.
truncate -s 3000M 06-imx-image-multimedia
e2fsck -f 06-imx-image-multimedia
resize2fs 06-imx-image-multimedia
Afterwards, an error occurs as shown below.
e2fsck 1.45.5 (07-Jan-2020)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open 06-imx-image-multimedia
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
What should I do now?
3,955件の閲覧回数
Rita_Wang
3,946件の閲覧回数
kiyoung
According to the document you pointed out, I can create ext4.
If there had been document from the beginning, it would have been less difficult, but the fragmented knowledge obtained through Googling had its limits.
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8MP%20swupdate%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B(ext4%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3Ei.MX%20Linux%20Yocto%20Project%20BSP%206.1.22_2.0.0%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3CBR%20%2F%3ENXP%20i.MX%208MPlus%20EVK%20(imx8mpevk)%3C%2FP%3E%3CP%3Eimx8MP%20%E3%81%A7%20swupdate%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SWUpdate%20OTA%20i.MX8MM%20EVK_rev3.pdf%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%80%8C%E7%94%BB%E5%83%8F%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%80%8D%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E06-imx-image-multimedia%20--%26gt%3B%20..%2Fslota%2Fimx-image-multimedia-imx8mmevk.ext4%3C%2FP%3E%3CP%3Ebitbake%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%20ext4%20%E5%BD%A2%E5%BC%8F%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82(wic.zst%20%E3%81%A8%20tar.zst%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3Eext4%E5%BD%A2%E5%BC%8F%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81wic.zst%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%8C%E7%94%BB%E5%83%8F%E3%81%AE%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%80%8D%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%96%E3%83%BC%E3%83%88ROM%7C%E3%83%96%E3%83%BC%E3%83%88%7C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8MP%E3%82%B9%E3%83%AF%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B(ext4%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%87%E6%91%98%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81ext4%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E5%88%9D%E3%81%8B%E3%82%89%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E9%9B%A3%E3%81%97%E3%81%8F%E3%81%AF%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%B0%E3%83%BC%E3%82%B0%E3%83%AB%E3%81%A7%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E6%96%AD%E7%89%87%E7%9A%84%E3%81%AA%E7%9F%A5%E8%AD%98%E3%81%AB%E3%81%AF%E9%99%90%E7%95%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8MP%E3%82%B9%E3%83%AF%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B(ext4%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8MP%E3%82%B9%E3%83%AF%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B(ext4%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%9C%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E06-IMX-%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8-%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%20-%26gt%3B%20..%2Fslota%2Fimx-image-multimedia-imx8mp-lpddr4-evk.wic.zst%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81readme.txt%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%82%8B%20-S%203000M%2006-IMX-%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8-%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3CBR%20%2F%3Ee2fsck%20-f%2006-imx-image-multimedia%3CBR%20%2F%3Eresize2fs%2006-imx-image-multimedia%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ee2fsck%201.45.5%20(2020%20%E5%B9%B4%201%20%E6%9C%88%207%20%E6%97%A5)%3CBR%20%2F%3Eext2fs_open2%3A%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E9%AD%94%E6%B3%95%E3%81%AE%E6%95%B0%E5%AD%97%E3%81%8C%E6%82%AA%E3%81%84%3CBR%20%2F%3Ee2fsck%3A%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3Ee2fsck%3A%2006-imx-image-multimedia%20%E3%82%92%E9%96%8B%E3%81%93%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF%E3%83%8A%E3%83%B3%E3%83%90%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%8B%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%20ext2%2Fext3%2Fext4%20%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%A7%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%20ext2%2Fext3%2Fext4%3CBR%20%2F%3E%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20(%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%82%84%20UFS%20%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84)%E3%80%81%E6%AC%A1%E3%81%AB%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3CBR%20%2F%3E%20%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%88%A5%E3%81%AE%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%20e2fsck%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20e2fsck%3CBR%20%2F%3E%20-b%208193%3CDEVICE%3E%3CBR%20%2F%3E%20%E5%8F%88%E3%81%AF%3CBR%20%2F%3E%20e2fsck%20-b%2032768%3CDEVICE%3E%3C%2FDEVICE%3E%3C%2FDEVICE%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3Aimx8MP%E3%82%B9%E3%83%AF%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B(ext4%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81wic.zst%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%8C%E7%94%BB%E5%83%8F%E3%81%AE%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%80%8D%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
