imx8MP swupdate inquiry (how to get ext4 image)
3,855 次查看
kiyoung
My environment is as follows.
i.MX Linux Yocto Project BSP 6.1.22_2.0.0 Release
NXP i.MX 8MPlus EVK (imx8mpevk)
To use swupdate for imx8MP, refer to SWUpdate OTA i.MX8MM EVK_rev3.pdf.
In the contents of "Image Assembling", there is the following:
06-imx-image-multimedia --> ../slota/imx-image-multimedia-imx8mmevk.ext4
There is no image in ext4 format in the output of bitbake. (There are wic.zst and tar.zst)
How can I get an image in ext4 format? Alternatively, can we proceed with “Image Assembling” using wic.zst?
3,792 次查看
Rita_Wang
You can refer to the document
4 回复数
3,827 次查看
Rita_Wang
Yes, you can use it, no problem.
3,811 次查看
kiyoung
Thank you for your reply
I made the below.
06-imx-image-multimedia -> ../slota/imx-image-multimedia-imx8mp-lpddr4-evk.wic.zst
And, according to the contents of readme.txt, I executed the following.
truncate -s 3000M 06-imx-image-multimedia
e2fsck -f 06-imx-image-multimedia
resize2fs 06-imx-image-multimedia
Afterwards, an error occurs as shown below.
e2fsck 1.45.5 (07-Jan-2020)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open 06-imx-image-multimedia
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
What should I do now?
3,793 次查看
Rita_Wang
3,784 次查看
kiyoung
According to the document you pointed out, I can create ext4.
If there had been document from the beginning, it would have been less difficult, but the fragmented knowledge obtained through Googling had its limits.
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8MP%20swupdate%20%E6%9F%A5%E8%AF%A2%EF%BC%88%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E7%8E%AF%E5%A2%83%E5%A6%82%E4%B8%8B%E3%80%82%3CBR%20%2F%3Ei.MX%20Linux%20Yocto%20%E9%A1%B9%E7%9B%AE%20BSP%206.1.22_2.0.0%20%E7%89%88%E6%9C%AC%3CBR%20%2F%3ENXP%20i.MX%208MPlus%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%20(imx8mpevk)%3C%2FP%3E%3CP%3E%E8%A6%81%E5%AF%B9%20imx8MP%20%E4%BD%BF%E7%94%A8%20swupdate%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20SWUpdate%20OTA%20i.MX8MM%20EVK_rev3.pdf%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E2%80%9C%E5%9B%BE%E5%83%8F%E7%BB%84%E8%A3%85%E2%80%9D%E7%9A%84%E5%86%85%E5%AE%B9%E4%B8%AD%E6%9C%89%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%2006-imx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93--%26gt%3B%20..%2Fslota%2Fimx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93-imx8mmevk.ext4%3C%2FP%3E%3CP%3Ebitbake%20%E7%9A%84%E8%BE%93%E5%87%BA%E4%B8%AD%E6%B2%A1%E6%9C%89%20ext4%20%E6%A0%BC%E5%BC%8F%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%EF%BC%88%E6%9C%89wic.zst%E5%92%8Ctar.zst%EF%BC%89%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E6%A0%BC%E5%BC%8F%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%9F%E6%88%96%E8%80%85%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20wic.zst%20%E8%BF%9B%E8%A1%8C%E2%80%9C%E5%9B%BE%E5%83%8F%E7%BB%84%E8%A3%85%E2%80%9D%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1855339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8MP%20swupdate%20%E6%9F%A5%E8%AF%A2%EF%BC%88%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E6%8C%87%E5%87%BA%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%20ext4%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%B8%80%E5%BC%80%E5%A7%8B%E5%B0%B1%E6%9C%89%E6%96%87%E7%8C%AE%E7%9A%84%E8%AF%9D%EF%BC%8C%E9%9A%BE%E5%BA%A6%E5%B0%B1%E4%BC%9A%E5%B0%8F%E4%B8%80%E4%BA%9B%EF%BC%8C%E4%BD%86%E6%98%AF%E9%80%9A%E8%BF%87%E8%B0%B7%E6%AD%8C%E6%90%9C%E7%B4%A2%E8%8E%B7%E5%BE%97%E7%9A%84%E7%A2%8E%E7%89%87%E5%8C%96%E7%9F%A5%E8%AF%86%E6%9C%89%E5%85%B6%E5%B1%80%E9%99%90%E6%80%A7%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8MP%20swupdate%20%E6%9F%A5%E8%AF%A2%EF%BC%88%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%96%87%E6%A1%A3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8MP%20swupdate%20%E6%9F%A5%E8%AF%A2%EF%BC%88%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%3C%2FP%3E%3CP%3E%E6%88%91%E5%81%9A%E4%BA%86%E4%BB%A5%E4%B8%8B%E4%BA%8B%E6%83%85%E3%80%82%3CBR%20%2F%3E06-imx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93-%26gt%3B..%2Fslota%2Fimx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93-imx8mp-lpddr4-evk.wic.zst%3C%2FP%3E%3CP%3E%E5%B9%B6%E4%B8%94%EF%BC%8C%E6%A0%B9%E6%8D%AE%20readme.txt%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E6%88%91%E6%89%A7%E8%A1%8C%E4%BA%86%E4%B8%8B%E5%88%97%E6%93%8D%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E6%88%AA%E6%96%AD-s%203000M%2006-imx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93%3CBR%20%2F%3Ee2fsck-f%2006-imx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93%3CBR%20%2F%3Eresize2fs%2006-imx-%E5%9B%BE%E5%83%8F%E5%A4%9A%E5%AA%92%E4%BD%93%3C%2FP%3E%3CP%3E%E4%B9%8B%E5%90%8E%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%A6%82%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3Ee2fsck%201.45.5%EF%BC%882020%E5%B9%B41%E6%9C%887%E6%97%A5%EF%BC%89%3CBR%20%2F%3E%20ext2fs_open2%EF%BC%9A%E8%B6%85%E7%BA%A7%E5%9D%97%E4%B8%AD%E7%9A%84%E5%B9%BB%E6%95%B0%E9%94%99%E8%AF%AF%3CBR%20%2F%3Ee2fsck%EF%BC%9A%E8%B6%85%E7%BA%A7%E5%9D%97%E6%97%A0%E6%95%88%EF%BC%8C%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%A4%87%E4%BB%BD%E5%9D%97...%3CBR%20%2F%3E%20e2fsck%EF%BC%9A%E5%B0%9D%E8%AF%95%E6%89%93%E5%BC%80%2006-imx-image-multimedia%20%E6%97%B6%E8%B6%85%E7%BA%A7%E5%9D%97%E4%B8%AD%E7%9A%84%E5%B9%BB%E6%95%B0%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E8%B6%85%E7%BA%A7%E5%9D%97%E6%88%96%E8%B6%85%E7%BA%A7%E5%9D%97%E6%9C%AA%E6%8F%8F%E8%BF%B0%E6%9C%89%E6%95%88%E7%9A%84%20ext2%2Fext3%2Fext4%3CBR%20%2F%3E%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E3%80%82%E5%A6%82%E6%9E%9C%E8%AE%BE%E5%A4%87%E6%9C%89%E6%95%88%E5%B9%B6%E4%B8%94%E7%A1%AE%E5%AE%9E%E5%8C%85%E5%90%AB%20ext2%2Fext3%2Fext4%3CBR%20%2F%3E%20%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%EF%BC%88%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BA%A4%E6%8D%A2%E6%88%96%20ufs%20%E6%88%96%E5%85%B6%E4%BB%96%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E6%98%AF%E8%B6%85%E7%BA%A7%E5%9D%97%3CBR%20%2F%3E%20%E5%B7%B2%E6%8D%9F%E5%9D%8F%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%A4%87%E7%94%A8%E8%B6%85%E7%BA%A7%E5%9D%97%E8%BF%90%E8%A1%8C%20e2fsck%EF%BC%9A%3CBR%20%2F%3E%20e2fsck%20-b%208193%3CDEVICE%3E%3CBR%20%2F%3E%20%E6%88%96%E8%80%85%3CBR%20%2F%3E%20e2fsck%20-b%2032768%3CDEVICE%3E%3C%2FDEVICE%3E%3C%2FDEVICE%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8MP%20swupdate%20%E6%9F%A5%E8%AF%A2%EF%BC%88%E5%A6%82%E4%BD%95%E8%8E%B7%E5%8F%96%20ext4%20%E5%9B%BE%E5%83%8F%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20wic.zst%20%E8%BF%9B%E8%A1%8C%E2%80%9C%E5%9B%BE%E5%83%8F%E7%BB%84%E8%A3%85%E2%80%9D%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
