Running normal tflite on MCXN947 without NPU mode
nnxxpp
I have a question about Running normal tflite on MCXN947 without NPU mode.
I saw that in the eiq examples from  SDK of MCXN947, all use NPU tflite with NPU mode. As mu understanding we can run normal tflite without NPU mode on MCXN947 only by changing resolvers. Is that right?
marek-trmac
Hi Nhanh Nao,
without NPU it should work too. NPU is recommended for better performance, with NPU it can be ~40-50 times faster.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
marek-trmac
Hi Nhanh Nao,
Marek
nnxxpp
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2019278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERunning%20normal%20tflite%20on%20MCXN947%20without%20NPU%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2019278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20a%20question%20about%26nbsp%3BRunning%20normal%20tflite%20on%20MCXN947%20without%20NPU%20mode.%3C%2FP%3E%3CP%3EI%20saw%20that%20in%20the%20eiq%20examples%20from%26nbsp%3B%20SDK%20of%26nbsp%3BMCXN947%2C%20all%20use%20NPU%20tflite%20with%20NPU%20mode.%20As%20mu%20understanding%20we%20can%20run%20%3CSTRONG%3Enormal%20tflite%26nbsp%3Bwithout%20NPU%20mode%26nbsp%3B%3C%2FSTRONG%3Eon%26nbsp%3BMCXN947%20only%20by%20changing%20resolvers.%20Is%20that%20right%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2019278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2019610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Running%20normal%20tflite%20on%20MCXN947%20without%20NPU%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2019610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2019597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Running%20normal%20tflite%20on%20MCXN947%20without%20NPU%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2019597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Nhanh%20Nao%2C%3C%2FP%3E%0A%3CP%3Ewithout%20NPU%20it%20should%20work%20too.%20NPU%20is%20recommended%20for%20better%20performance%2C%20with%20NPU%20it%20can%20be%20~40-50%20times%20faster.%3C%2FP%3E%3C%2FLINGO-BODY%3E
