RT1176 EXT memory pinout
1,176件の閲覧回数
Engineer_xxx
Hello team
Im using W9825G6KH with MIMXRT1176, and I couldn't find 2 signals from the memory named (LDQM, UDQM) to be routed with MIMXRT1176 . If you see the picture below from MCUXpresso config tools, there are no similar names so I can match with the memory. Could you help please. Thanks ahead for your support
ラベル(2)
1,143件の閲覧回数
Gavin_Jia
Hi @Engineer_xxx ,
It is SEMC_DMx signal. Please refer to the EVK/EVKB schematic.
Gavin
2 返答(返信)
1,144件の閲覧回数
Gavin_Jia
Hi @Engineer_xxx ,
Gavin
1,127件の閲覧回数
Engineer_xxx
Big Thanks Gavin
