#MCXN547 ethernet
#MCXN547 ethernet
jeremyyang
HI Sir ,
We use MCXN547VKLT MCU + KSZ8081RNBIA (PHY ) ,
and need to test 10M Compliance test , After check to Microchip ,
We need set register form MCU to pseudo random pattern ,
DO you know how to set up the Firmware ?@joey
from microship as below
the test signal need generate from MAC' and through MII/RMII to PHY to generate packets
Labels (2)
Tags (2)
EdwinHz
Hi @jeremyyang,
Please take a look at the enet example codes that you can find from the MCX-N5XX-EVK SDK. There, you will find the base line on how to configure the ethernet peripheral for the compliance test your require.
BR,
Edwin.
jeremyyang
from lab , need configure idle pattern (random Data )
how to configure ?
jeremyyang
add test item
%3CLINGO-SUB%20id%3D%22lingo-sub-2200818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%23MCXN547%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Sir%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20use%26nbsp%3BMCXN547VKLT%20MCU%20%2B%26nbsp%3BKSZ8081RNBIA%20(PHY%20)%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3Eand%20need%20to%20test%2010M%20Compliance%20test%20%2C%20After%20check%20to%20Microchip%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20need%20set%20register%20form%20MCU%20to%26nbsp%3Bpseudo%20random%20pattern%20%2C%3C%2FP%3E%3CP%3EDO%20you%20know%20how%20to%20set%20up%20the%20Firmware%20%3F%40joey%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3Efrom%20microship%20as%20below%26nbsp%3B%3C%2FP%3E%3CP%3Ethe%20test%20signal%20need%20generate%20from%20MAC'%20and%20through%20MII%2FRMII%20to%20PHY%20to%20generate%20packets%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2200818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2202138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%23MCXN547%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256646%22%20target%3D%22_blank%22%3E%40jeremyyang%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EPlease%20take%20a%20look%20at%20the%20enet%20example%20codes%20that%20you%20can%20find%20from%20the%26nbsp%3BMCX-N5XX-EVK%20SDK.%20There%2C%20you%20will%20find%20the%20base%20line%20on%20how%20to%20configure%20the%20ethernet%20peripheral%20for%20the%20compliance%20test%20your%20require.%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2201410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%23MCXN547%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2201410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Efrom%20lab%20%2C%20need%20configure%20idle%20pattern%20(random%20Data%20)%3C%2FP%3E%3CP%3Ehow%20to%20configure%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%23MCXN547%20ethernet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200819%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eadd%20test%20item%3C%2FP%3E%3C%2FLINGO-BODY%3E
