MCXN 947 how to interrupt to slave mcu by gpio pin
已解决
跳至解决方案
854 次查看
Steven_Tai
FRDM-MCXN947 what can I do,  if i want to get the gpio pin interrupt by slave mcu  (such as gpio0 pin6)
标签 (1)
1 解答
835 次查看
ZhangJennie
Hello @Steven_Tai
I suggest you referring SDK demo code pin interrupt. I believe it will help you.
Best Regards
Jun Zhang
在原帖中查看解决方案
3 回复数
836 次查看
ZhangJennie
Hello @Steven_Tai
Best Regards
Jun Zhang
797 次查看
Steven_Tai
how to use the GPIO00 interrupt slave mcu directly without pinmux? I was failed with GPIO00_Interrupt to slave mcu.
标记 (1)
665 次查看
ZhangJennie
If pin interrupt is needed, we must configure PINT_SEL registers in the INPUTMUX module to make sure the pin served as PINT function.
