MCXC and EEPROM emulation
997 次查看
pepoja
Hi there,
Please, Is able to use internal FLASH memory in the MCXC242 as a emulated EEPROM/Non-Volatile Memory for store users application settings (few bytes) during running application?
In some LPC microcontrollers is API for In-Application programming which make it possible. How about MCXC242?
Or one and only way is to connect external EEPROM?
Thanks.
Peter
937 次查看
Hello @pepoja
If you mean software emulate EEPROM, yes, mcxc242 supports emulated EEPROM.
You can refer to: https://www.nxp.com.cn/docs/en/application-note/AN13542.pdf
Alice
938 次查看
Hello @pepoja
Alice
