MCUXpresso + FRDM-MCXN947: Failed to import project from Application Code Hub
606 次查看
wycox
Hi, I tried for many times to import eIQ project from Application Code Hub, and failed with an error msg " Currently selected project is not supported by MCUXpresso IDE", as shown in the upper left corner of the attached screen shot. However I do can import the project with the same name from installed SDK package. What could be the reason for this problem? Thanks for help.
标签 (2)
574 次查看
Harry_Zhang
Hi @wycox
Thank you for providing the information. We will resolve this issue as soon as possible.
Harry
