How to use SD card for storage ML model?
896 次查看
nnxxpp
My board is MCXN947 but internal flash is 2 MB. It is small for my tflite model. I know that MCXN947 supports SD card. How can I use SD card to save and run my model? I want to the flow is same before. Before I use the internal flash and debug via USB.
Thank you.
820 次查看
nnxxpp
@Harry_Zhang
Thanks.
So in my case the external flash maybe is the best solution. How do you think about it? Please give me some advice and tutorials.
809 次查看
Harry_Zhang
Hi @nnxxpp
I think you can use external flash to store your code and XIP.
So you can refer to hello_world_qspi_xip example.
Harry
835 次查看
Harry_Zhang
Hi @nnxxpp
If you want to save your model in SD card, this is possible.
You can refer to this example.
But MCXN947 doesn't support booting from SD card.
Harry
