How to verify the communication function of two LIN channels on the Linux driver of BSP37 when there are two LIN channels on the S32g274A RDB2 development board
Hello, @LB666
Thanks for the question
Seems you want to test the LIN under Linux in BSP37? Well, current Linux BSP releases do not include support for the LIN mode of LinFlexD, only UART mode supported in newer BSP versions.
If you want to verify the LIN functions, we suggest using the drivers available in RTD SW packages.
Best Regards
Chenyin
