FRDM-MCXN947 Cannot download program to chip
1,384 次查看
dreamdf
MCUXpresso IDE RedlinkMulti Driver v24.9
Reconnected to existing LinkServer process.
Connecting to probe 1 core 0 (using server started externally) reports:
Could not connect to core
I flash my program via kiel a few times.I come across debug abort when i try to
debug.Then I lost my board, series port works well, but cannot flash new project
5 回复数
1,354 次查看
diego_charles
Hi @dreamdf
It seems that your MCU is temporally bricked.
To recover the debug access, please try to set the MCU into ISP mode, this way bootROM will execute, setting the MCU into a known state. Once it is set into this state, please try to do a mass erase and program your application one more time.
Please let me know your results.
Diego
1,287 次查看
dreamdf
I use MCUXpresso Secure Provisioning Tool flash a demo successfully.
Program run normally.
But cannot flash KEil project bin file.Program doesnot run.
Still canont download file via keil or MCXpresso IDE
Program MCU-Link CMSIS-DAP - CNXPMCU-LINK_installer cannot updata debugger.
标记 (1)
1,140 次查看
diego_charles
Hi @dreamdf
I am sorry for the delayed respose, I missed your reply.
I understand that you can program over ISP, but did you used USB connection or UART?
Did you manage to find out something else during this time? If yes please let me know.
Other thing we could check is : jumper setup on your FRDM board, could you share a picture where we can see the jumpers?
Diego
1,326 次查看
dreamdf
I downloaded blhost and entry isp mode successfully, I erased flash and downloaded a offical demo.But My Board still doesnot work after resetting.
1,343 次查看
dreamdf
Hello,How can I set the FRDM-MCXN947 into ISP mode,And what should I do to erase the flashed program.
Sorry for this simple question, I am a Newbie
