Custom YOLO model on MCXN947
1,172 次查看
jm4622
I'm trying to use a custom YOLOv1 model for person detection (by modifying the example). However,despite the model being relatively small, I'm getting excessive RAM usage and overflowing ie:
Failed to resize buffer. Requested: 399776, available 376504, missing: 23272
I have attached my model, both in tflite format and its converted format (using neutron converter). Would someone be able to point out the cause of itsexcessive RAM use and suggest possible optimizations?
标签 (1)
1 回复
1,095 次查看
Harry_Zhang
Hi @jm4622
Your issue seems to be related to excessive RAM usage by your custom YOLOv1 model.
Can you share your project?
Harry
