Where do I enter a "post-build" step (script) when using MCUXpresso for VS Code?
2,168 次查看
CktDesigner
I converted a project from the MCUXpresso IDE to MCUXpresso for VS Code.   I have everything working except for the "post-build" steps...
In MCUXpresso, post-build steps can be specified in Properties->C/C++Build-?Settings->BuildSteps
Where is the equivalent in the VS Code version?
Thanks!
2,147 次查看
cristiantepus
We did not implement this to be automatically done yet. We'll add it in a future release. Till then, you can work around the issue by adding a custom command with post build step (in CMakeLists.txt) like in the example below:
ADD_CUSTOM_COMMAND(TARGET ${MCUX_SDK_PROJECT_NAME} POST_BUILD COMMAND echo ${EXECUTABLE_OUTPUT_PATH}/${MCUX_SDK_PROJECT_NAME})
Some other example, if you import from SDK a multicore project, core1 is generating a bin from an executable file in a similar post build command:
ADD_CUSTOM_COMMAND(TARGET ${MCUX_SDK_PROJECT_NAME} POST_BUILD COMMAND ${CMAKE_OBJCOPY}
-Obinary ${EXECUTABLE_OUTPUT_PATH}/${MCUX_SDK_PROJECT_NAME} ${EXECUTABLE_OUTPUT_PATH}/core1_image.bin)
Cristian
2,088 次查看
CktDesigner
Thanks!!
2,148 次查看
cristiantepus
Cristian
%3CLINGO-SUB%20id%3D%22lingo-sub-1914477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20MCUXpresso%20for%20VS%20Code%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E8%BE%93%E5%85%A5%E2%80%9C%E6%9E%84%E5%BB%BA%E5%90%8E%E2%80%9D%E6%AD%A5%E9%AA%A4%EF%BC%88%E8%84%9A%E6%9C%AC%EF%BC%89%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1914477%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%86%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%BB%8E%20MCUXpresso%20IDE%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%20MCUXpresso%20for%20VS%20Code%E3%80%82%E9%99%A4%E4%BA%86%E2%80%9C%E5%90%8E%E6%9C%9F%E6%9E%84%E5%BB%BA%E2%80%9D%E6%AD%A5%E9%AA%A4%E5%A4%96%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8......%3C%2FP%3E%3CP%3E%E5%9C%A8%20MCUXpresso%20%E4%B8%AD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Properties-%26gt%3BC%2FC%2B%2BBuild-%3FSettings-%26gt%3BBuildSteps%20%E4%B8%AD%E6%8C%87%E5%AE%9A%E6%9E%84%E5%BB%BA%E5%90%8E%E6%AD%A5%E9%AA%A4%3C%2FP%3E%3CP%3EVS%20Code%20%E7%89%88%E6%9C%AC%E4%B8%AD%E7%9A%84%E7%AD%89%E6%95%88%E9%A1%B9%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1919962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20MCUXpresso%20for%20VS%20Code%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E8%BE%93%E5%85%A5%E2%80%9C%E6%9E%84%E5%BB%BA%E5%90%8E%E2%80%9D%E6%AD%A5%E9%AA%A4%EF%BC%88%E8%84%9A%E6%9C%AC%EF%BC%89%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1919962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
