MCUXpresso for VSCode cannot run hello on MCXN947
marcocavallini
Contributor V
I am experimenting with MCXN947 using MCUXpresso for VSCode.
  • Build machine Ubuntu 22.04.
  • VSCode version 1.88.1
Installed the components using MCUXpresso Installer v.1.2
  • MCUXpresso SDK (2.14.0)
  • LinkServer
  • ARM GNU toolchain
  • Standalone toolchain addons
  • CMSIS toolbox
Then I followed the excellent guide Getting Started with MCUXpresso for Visual Studio Code by @kyledando
I am able to build frdmmcxn947_hello_world
The board is connected via USB-C cable (J17 MCU-LINK) to the PC (USB Port)
And detected as MCU-LINK FRDM-MCXN947
$ lsusb
Bus 001 Device 087: ID 1fc9:0143 NXP Semiconductors MCU-LINK FRDM-MCXN947 (r0E7) CMSIS-DAP V3.128
Unfortunately when I try to debug it I get popup message showing "Unable to start debugging. Debug server process failed to initialize".
The message pretends to open launch.json
  "configurations": [
      "type": "cppdbg",
      "name": "Debug project configuration",
      "request": "launch",
      "cwd": "${workspaceRoot}",
      "MIMode": "gdb",
      "setupCommands": [
        {"text": "set remotetimeout 600"},
        {"text": "set debug-file-directory"}
      "program": "",
      "miDebuggerServerAddress": "", // Remote GDB server address. If this is provided, "debugServerPath" will not be auto-completed.
      "variables": {
        "mcuxStopAtSymbol": "main", // Initial breakpoint
        "mcuxSerialNumber": "HU4NSCTMxxxxx", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxAttach": "false", // Start debug in attach mode
        "mcuxRemoteProbeType": "", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
        "mcuxSkipBuildWhenDebug": "false" // Skip build when debug
      "logging": {
        "engineLogging": false
At this point I'm stuck and I can't figure out how to proceed.
Any help would be appreciated.
nicu_manescu
Hi @marcocavallini,
The log does not contain relevant information. Additional info should be logged after:
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [read] Loading "LS_preconnect_MCXN9XX.scp"
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [write] run
Could you please try an erase first. This worked in a similar situation (see previous replies).
Nicu
jwolinski
Hi @cristiantepus @Pavel_Hernandez I'm trying to run debug session in VSCode. I have similar setup, except I'm using Windows OS.
I have similar issue, this is my launch.json file:
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "D:\\vscode\\projects\\embedded\\frdm-mcxn947\\frdmmcxn947_led_blinky\\armgcc\\debug\\led_blinky.elf",
      "miDebuggerPath": "D:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin\\arm-none-eabi-gdb.exe",
      "miDebuggerArgs": "localhost:3333",
      "variables": {
        "mcuxSerialNumber": "JUSOLFVVYXBVB", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxRemoteProbeType": "LinkServer", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
      "logging": {
        "engineLogging": true
cristiantepus
Hi @jwolinski ,
Can you please try an erase first (right click on project + erase, or, go to QuickStart Panel -> Flash Programmer -> Erase) then a debug again? Does this solve your connectivity issue?
Cristian
jwolinski
Hi @cristiantepus, yes I think this was a problem.
Pavel_Hernandez
Hello, sorry for the late response, I tried on mi Linux PC and at the first time have the same issue but then the VSCODE detect the board and I will start the Debug session.
"configurations": [
"type": "cppdbg",
"MIMode": "gdb",
"setupCommands": [
"program": "",
"variables": {
"mcuxSerialNumber": "WLEDDEPSMN35Q",
"logging": {
"name": "C/C++: gcc-11 build and debug active file",
"type": "cppdbg",
"program": "${fileDirname}/${fileBasenameNoExtension}",
"args": [],
"stopAtEntry": false,
"cwd": "${fileDirname}",
"environment": [],
"externalConsole": false,
"MIMode": "gdb",
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"description": "Set Disassembly Flavor to Intel",
"text": "-gdb-set disassembly-flavor intel",
"preLaunchTask": "C/C++: gcc-11 build active file",
"miDebuggerPath": "/usr/bin/gdb","variables": {"mcuxSerialNumber":"WLEDDEPSMN35Q"}
"version": "2.0.0"
Look the differences from your JSON.
Let me know about the status of your issue.
Pavel
jwolinski
Hello, no problem. For me the issue was solved right after I specifed Flash Programmer to Link Server in this window:
After that i flashed the board and finally I could start debug session, however I'm wondering why it was working because some fileds in json file like program,  was not specified.
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "",
      "miDebuggerArgs": "",
      "variables": {
      "logging": {
Thanks for your anwser!
cristiantepus
Can you please make enableLogging as true in your launch config, debug once again and attach here the log?
Cristian
marcocavallini
Contributor V
Hi @cristiantepus
Sorry for the late reply.
Please find the attached build-log.txt file
nicu_manescu
Hi @marcocavallini,
Nicu
marcocavallini
Contributor V
@nicu_manescu
erasing flash prior to start debugging solved the issue. Now it works!
Thank you
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information testing this.
Pavel
