MCUXpresso for VSCode cannot run hello on MCXN947
13,276 次查看
marcocavallini
I am experimenting with MCXN947 using MCUXpresso for VSCode.
  • Build machine Ubuntu 22.04.
  • VSCode version 1.88.1
Installed the components using MCUXpresso Installer v.1.2
  • MCUXpresso SDK (2.14.0)
  • LinkServer
  • ARM GNU toolchain
  • Standalone toolchain addons
  • CMSIS toolbox
Then I followed the excellent guide Getting Started with MCUXpresso for Visual Studio Code by @kyledando
I am able to build frdmmcxn947_hello_world
The board is connected via USB-C cable (J17 MCU-LINK) to the PC (USB Port)
And detected as MCU-LINK FRDM-MCXN947
$ lsusb
Bus 001 Device 087: ID 1fc9:0143 NXP Semiconductors MCU-LINK FRDM-MCXN947 (r0E7) CMSIS-DAP V3.128
Unfortunately when I try to debug it I get popup message showing "Unable to start debugging. Debug server process failed to initialize".
The message pretends to open launch.json
  "configurations": [
      "type": "cppdbg",
      "name": "Debug project configuration",
      "request": "launch",
      "cwd": "${workspaceRoot}",
      "MIMode": "gdb",
      "setupCommands": [
        {"text": "set remotetimeout 600"},
        {"text": "set debug-file-directory"}
      "program": "",
      "miDebuggerServerAddress": "", // Remote GDB server address. If this is provided, "debugServerPath" will not be auto-completed.
      "variables": {
        "mcuxStopAtSymbol": "main", // Initial breakpoint
        "mcuxSerialNumber": "HU4NSCTMxxxxx", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxAttach": "false", // Start debug in attach mode
        "mcuxRemoteProbeType": "", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
        "mcuxSkipBuildWhenDebug": "false" // Skip build when debug
      "logging": {
        "engineLogging": false
At this point I'm stuck and I can't figure out how to proceed.
Any help would be appreciated.
标记 (4)
12,688 次查看
nicu_manescu
Hi @marcocavallini,
The log does not contain relevant information. Additional info should be logged after:
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [read] Loading "LS_preconnect_MCXN9XX.scp"
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [write] run
Could you please try an erase first. This worked in a similar situation (see previous replies).
Nicu
10 回复数
13,073 次查看
jwolinski
Hi @cristiantepus @Pavel_Hernandez I'm trying to run debug session in VSCode. I have similar setup, except I'm using Windows OS.
I have similar issue, this is my launch.json file:
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "D:\\vscode\\projects\\embedded\\frdm-mcxn947\\frdmmcxn947_led_blinky\\armgcc\\debug\\led_blinky.elf",
      "miDebuggerPath": "D:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin\\arm-none-eabi-gdb.exe",
      "miDebuggerArgs": "localhost:3333",
      "variables": {
        "mcuxSerialNumber": "JUSOLFVVYXBVB", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxRemoteProbeType": "LinkServer", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
      "logging": {
        "engineLogging": true
13,009 次查看
cristiantepus
Hi @jwolinski ,
Can you please try an erase first (right click on project + erase, or, go to QuickStart Panel -> Flash Programmer -> Erase) then a debug again? Does this solve your connectivity issue?
Cristian
13,005 次查看
jwolinski
Hi @cristiantepus, yes I think this was a problem.
13,019 次查看
Pavel_Hernandez
Hello, sorry for the late response, I tried on mi Linux PC and at the first time have the same issue but then the VSCODE detect the board and I will start the Debug session.
"configurations": [
"type": "cppdbg",
"MIMode": "gdb",
"setupCommands": [
"program": "",
"variables": {
"mcuxSerialNumber": "WLEDDEPSMN35Q",
"logging": {
"name": "C/C++: gcc-11 build and debug active file",
"type": "cppdbg",
"program": "${fileDirname}/${fileBasenameNoExtension}",
"args": [],
"stopAtEntry": false,
"cwd": "${fileDirname}",
"environment": [],
"externalConsole": false,
"MIMode": "gdb",
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"description": "Set Disassembly Flavor to Intel",
"text": "-gdb-set disassembly-flavor intel",
"preLaunchTask": "C/C++: gcc-11 build active file",
"miDebuggerPath": "/usr/bin/gdb","variables": {"mcuxSerialNumber":"WLEDDEPSMN35Q"}
"version": "2.0.0"
Look the differences from your JSON.
Let me know about the status of your issue.
Pavel
13,006 次查看
jwolinski
Hello, no problem. For me the issue was solved right after I specifed Flash Programmer to Link Server in this window:
After that i flashed the board and finally I could start debug session, however I'm wondering why it was working because some fileds in json file like program,  was not specified.
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "",
      "miDebuggerArgs": "",
      "variables": {
      "logging": {
Thanks for your anwser!
13,127 次查看
cristiantepus
Can you please make enableLogging as true in your launch config, debug once again and attach here the log?
Cristian
12,756 次查看
marcocavallini
Hi @cristiantepus
Sorry for the late reply.
Please find the attached build-log.txt file
12,689 次查看
nicu_manescu
Hi @marcocavallini,
Nicu
12,672 次查看
marcocavallini
@nicu_manescu
erasing flash prior to start debugging solved the issue. Now it works!
Thank you
13,221 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information testing this.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1849077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3CSTRONG%3EMCUXpresso%20%E5%AF%B9%20VSCode%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%3CSTRONG%3EMCXN947%3C%2FSTRONG%3E%E8%AF%95%E9%AA%8C%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%9E%84%E5%BB%BA%E6%9C%BA%E5%99%A8%3CSTRONG%3EUbuntu%2022.04%3C%2FSTRONG%3E%20%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EVSCode%3C%2FSTRONG%3E%E7%89%88%E6%9C%AC%3CSTRONG%3E1.88.1%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E4%BD%BF%E7%94%A8%3CSTRONG%3EMCUXpresso%20Installer%20v.1.2%3C%2FSTRONG%3E%E5%AE%89%E8%A3%85%E7%BB%84%E4%BB%B6%3C%2FP%3E%3CUL%3E%3CLI%3EMCUXpresso%20SDK%20(2.14.0)%3C%2FLI%3E%3CLI%3ELinkServer%3C%2FLI%3E%3CLI%3EARM%20GNU%20%E5%B7%A5%E5%85%B7%E9%93%BE%3C%2FLI%3E%3CLI%3E%E7%8B%AC%E7%AB%8B%E5%B7%A5%E5%85%B7%E9%93%BE%E6%8F%92%E4%BB%B6%3C%2FLI%3E%3CLI%3ECMSIS%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%8C%89%E7%85%A7%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F193716%22%20target%3D%22_blank%22%3E%20%40kyledando%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Ftraining%2Fgetting-started-with-mcuxpresso-for-visual-studio-code%3ATIP-GETTING-STARTED-WITH-MCUXPRESSO-FOR-VS-CODE%3FSAMLart%3DST-AAF0E3YJDJej%252BJVBprc7Vu5rkUdezz2Xd17s%252F27bgltNLOpmAEfiv3wm%23colkp5maoqd%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%9A%84%E4%BC%98%E7%A7%80%E6%8C%87%E5%8D%97%20%E3%80%8AMCUXpresso%20for%20Visual%20Studio%20Code%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%E3%80%8B%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E6%9E%84%E5%BB%BA%3CSTRONG%3Efrdmmcxn947_hello_world%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E6%9D%BF%E9%80%9A%E8%BF%87%20USB-C%20%E7%94%B5%E7%BC%86%EF%BC%88J17%20MCU-LINK%EF%BC%89%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%EF%BC%88USB%20%E7%AB%AF%E5%8F%A3%EF%BC%89%3C%2FP%3E%3CP%3E%E5%B9%B6%E6%A3%80%E6%B5%8B%E4%B8%BAMCU-LINK%20FRDM-MCXN947%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%24%20lsusb%0ABus%20001%20Device%20087%3A%20ID%201fc9%3A0143%20NXP%20Semiconductors%20MCU-LINK%20FRDM-MCXN947%20(r0E7)%20CMSIS-DAP%20V3.128%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%E5%AE%83%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E5%BC%B9%E5%87%BA%E6%B6%88%E6%81%AF%EF%BC%8C%E6%98%BE%E7%A4%BA%E2%80%9C%E6%97%A0%E6%B3%95%E5%BC%80%E5%A7%8B%E8%B0%83%E8%AF%95%E3%80%82%E8%B0%83%E8%AF%95%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%9B%E7%A8%8B%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E6%B6%88%E6%81%AF%E5%81%87%E8%A3%85%E6%89%93%E5%BC%80%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-java%22%3E%3CCODE%20translate%3D%22no%22%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22miDebuggerServerAddress%22%3A%20%22%22%2C%20%2F%2F%20Remote%20GDB%20server%20address.%20If%20this%20is%20provided%2C%20%22debugServerPath%22%20will%20not%20be%20auto-completed.%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22HU4NSCTMxxxxx%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20false%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E5%88%BB%E6%88%91%E9%99%B7%E5%85%A5%E4%BA%86%E5%9B%B0%E5%A2%83%EF%BC%8C%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E5%A6%82%E4%BD%95%E7%BB%A7%E7%BB%AD%E4%B8%8B%E5%8E%BB%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%E9%83%BD%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24047%22%20target%3D%22_blank%22%3E%40nicu_manescu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%BC%80%E5%A7%8B%E8%B0%83%E8%AF%95%E4%B9%8B%E5%89%8D%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%E8%A7%A3%E5%86%B3%E4%BA%86%E8%AF%A5%E9%97%AE%E9%A2%98%E3%80%82%E7%8E%B0%E5%9C%A8%E5%AE%83%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F6688%22%20target%3D%22_blank%22%3E%40marcocavallini%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%97%A5%E5%BF%97%E4%B8%8D%E5%8C%85%E5%90%AB%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E3%80%82%E9%99%84%E5%8A%A0%E4%BF%A1%E6%81%AF%E5%BA%94%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%97%B6%E9%97%B4%E8%AE%B0%E5%BD%95%EF%BC%9A%3CBR%20%2F%3E%20%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CFONT%20face%3D%22terminal%2Cmonaco%22%3E%5B%E8%AD%A6%E5%91%8A%5D%201%EF%BC%9A%EF%BC%883221%EF%BC%89STDERR%EF%BC%9A%5B2900%5D%20DEBUG%EF%BC%9Alauncher.core.redlinkserv%EF%BC%9A%5B%E8%AF%BB%E5%8F%96%5D%20%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BD%E2%80%9CLS_preconnect_MCXN9XX.scp%E2%80%9D%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22terminal%2Cmonaco%22%3E%5B%E8%AD%A6%E5%91%8A%5D%201%EF%BC%9A%EF%BC%883221%EF%BC%89STDERR%EF%BC%9A%5B2900%5D%20DEBUG%EF%BC%9Alauncher.core.redlinkserv%EF%BC%9A%5B%E5%86%99%E5%85%A5%5D%20%E8%BF%90%E8%A1%8C%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%85%88%E5%B0%9D%E8%AF%95%E6%93%A6%E9%99%A4%EF%BC%9F%E8%BF%99%E5%9C%A8%E7%B1%BB%E4%BC%BC%E6%83%85%E5%86%B5%E4%B8%8B%E4%B9%9F%E6%9C%89%E6%95%88%EF%BC%88%E8%A7%81%E4%B9%8B%E5%89%8D%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3ENicu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%3CBR%20%2F%3E%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%99%84%E4%BB%B6%E7%9A%84%3CSTRONG%3Ebuild-log.txt%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%20%EF%BC%8C%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E5%9C%A8%E6%88%91%E5%9C%A8%E6%AD%A4%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%B0%86%20Flash%20%E7%BC%96%E7%A8%8B%E5%99%A8%E6%8C%87%E5%AE%9A%E4%B8%BA%E9%93%BE%E6%8E%A5%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_1-1714026113557.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_1-1714026113557.png%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275767iBD0480A684FCD5CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_1-1714026113557.png%22%20alt%3D%22jwolinski_1-1714026113557.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_0-1714025888403.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_0-1714025888403.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275765iCF5B3386EBC0E27C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_0-1714025888403.png%22%20alt%3D%22jwolinski_0-1714025888403.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B9%8B%E5%90%8E%E6%88%91%E5%88%B7%E6%96%B0%E4%BA%86%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%B9%B6%E6%9C%80%E7%BB%88%E5%8F%AF%E4%BB%A5%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%AE%83%E4%B8%BA%E4%BB%80%E4%B9%88%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%20json%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E4%B8%80%E4%BA%9B%E6%96%87%E4%BB%B6%EF%BC%88%E5%A6%82%3CSTRONG%3E%E7%A8%8B%E5%BA%8F%EF%BC%89%3C%2FSTRONG%3E%E6%B2%A1%E6%9C%89%E6%8C%87%E5%AE%9A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22miDebuggerArgs%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22JUSOLFVVYXBVB%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22LinkServer%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20true%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232678%22%20target%3D%22_blank%22%3E%40jwolinski%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%85%88%E5%B0%9D%E8%AF%95%E6%93%A6%E9%99%A4%EF%BC%88%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E9%A1%B9%E7%9B%AE%2B%E6%93%A6%E9%99%A4%EF%BC%8C%E6%88%96%E8%80%85%E8%BD%AC%E5%88%B0%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E9%9D%A2%E6%9D%BF-%26gt%3B%20Flash%20%E7%BC%96%E7%A8%8B%E5%99%A8-%26gt%3B%20%E6%93%A6%E9%99%A4%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%9F%E8%BF%99%E8%83%BD%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%85%8B%E9%87%8C%E6%96%AF%E8%92%82%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%EF%BC%8C%E6%88%91%E5%9C%A8%20mi%20Linux%20PC%20%E4%B8%8A%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E7%AC%AC%E4%B8%80%E6%AC%A1%E9%81%87%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%20VSCODE%20%E6%A3%80%E6%B5%8B%E5%88%B0%E4%BA%86%E4%B8%BB%E6%9D%BF%EF%BC%8C%E6%88%91%E5%B0%86%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%7B%0A%22configurations%22%3A%20%5B%0A%7B%0A%22type%22%3A%20%22cppdbg%22%2C%0A%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%22request%22%3A%20%22launch%22%2C%0A%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%22MIMode%22%3A%20%22gdb%22%2C%0A%22setupCommands%22%3A%20%5B%0A%7B%0A%22text%22%3A%20%22set%20remotetimeout%20600%22%0A%7D%2C%0A%7B%0A%22text%22%3A%20%22set%20debug-file-directory%22%0A%7D%0A%5D%2C%0A%22program%22%3A%20%22%22%2C%0A%22miDebuggerServerAddress%22%3A%20%22%22%2C%0A%22variables%22%3A%20%7B%0A%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%0A%22mcuxSerialNumber%22%3A%20%22WLEDDEPSMN35Q%22%2C%0A%22mcuxAttach%22%3A%20%22false%22%2C%0A%22mcuxRemoteProbeType%22%3A%20%22%22%2C%0A%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%0A%7D%2C%0A%22logging%22%3A%20%7B%0A%22engineLogging%22%3A%20false%0A%7D%0A%7D%2C%0A%7B%0A%22name%22%3A%20%22C%2FC%2B%2B%3A%20gcc-11%20build%20and%20debug%20active%20file%22%2C%0A%22type%22%3A%20%22cppdbg%22%2C%0A%22request%22%3A%20%22launch%22%2C%0A%22program%22%3A%20%22%24%7BfileDirname%7D%2F%24%7BfileBasenameNoExtension%7D%22%2C%0A%22args%22%3A%20%5B%5D%2C%0A%22stopAtEntry%22%3A%20false%2C%0A%22cwd%22%3A%20%22%24%7BfileDirname%7D%22%2C%0A%22environment%22%3A%20%5B%5D%2C%0A%22externalConsole%22%3A%20false%2C%0A%22MIMode%22%3A%20%22gdb%22%2C%0A%22setupCommands%22%3A%20%5B%0A%7B%0A%22description%22%3A%20%22Enable%20pretty-printing%20for%20gdb%22%2C%0A%22text%22%3A%20%22-enable-pretty-printing%22%2C%0A%22ignoreFailures%22%3A%20true%0A%7D%2C%0A%7B%0A%22description%22%3A%20%22Set%20Disassembly%20Flavor%20to%20Intel%22%2C%0A%22text%22%3A%20%22-gdb-set%20disassembly-flavor%20intel%22%2C%0A%22ignoreFailures%22%3A%20true%0A%7D%0A%5D%2C%0A%22preLaunchTask%22%3A%20%22C%2FC%2B%2B%3A%20gcc-11%20build%20active%20file%22%2C%0A%22miDebuggerPath%22%3A%20%22%2Fusr%2Fbin%2Fgdb%22%2C%22variables%22%3A%20%7B%22mcuxSerialNumber%22%3A%22WLEDDEPSMN35Q%22%7D%0A%7D%0A%5D%2C%0A%22version%22%3A%20%222.0.0%22%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E6%9F%A5%E7%9C%8B%E4%B8%8E%E6%82%A8%E7%9A%84%20JSON%20%E4%B9%8B%E9%97%B4%E7%9A%84%E5%B7%AE%E5%BC%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E8%AE%A9%E6%88%91%E4%BA%86%E8%A7%A3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1853419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1853419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%20VSCode%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E3%80%82%E6%88%91%E6%9C%89%E7%B1%BB%E4%BC%BC%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Windows%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%20translate%3D%22no%22%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22D%3A%5C%5Cvscode%5C%5Cprojects%5C%5Cembedded%5C%5Cfrdm-mcxn947%5C%5Cfrdmmcxn947_led_blinky%5C%5Carmgcc%5C%5Cdebug%5C%5Cled_blinky.elf%22%2C%0A%20%20%20%20%20%20%22miDebuggerPath%22%3A%20%22D%3A%5C%5CProgram%20Files%20(x86)%5C%5CGNU%20Arm%20Embedded%20Toolchain%5C%5C10%202021.10%5C%5Cbin%5C%5Carm-none-eabi-gdb.exe%22%2C%0A%20%20%20%20%20%20%22miDebuggerArgs%22%3A%20%22localhost%3A3333%22%2C%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22JUSOLFVVYXBVB%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22LinkServer%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20true%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_0-1713958589547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_0-1713958589547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275545i7A5706CF7DB13185%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_0-1713958589547.png%22%20alt%3D%22jwolinski_0-1713958589547.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1851231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1851231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%9C%A8%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%E4%B8%AD%E5%B0%86%20enableLogging%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20true%EF%BC%8C%E5%86%8D%E6%AC%A1%E8%B0%83%E8%AF%95%E5%B9%B6%E5%9C%A8%E6%AD%A4%E5%A4%84%E9%99%84%E5%8A%A0%E6%97%A5%E5%BF%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%85%8B%E9%87%8C%E6%96%AF%E8%92%82%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMCUXpresso%20for%20VSCode%20%E6%97%A0%E6%B3%95%E5%9C%A8%20MCXN947%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20hello%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E5%8F%AB%E5%B8%95%E7%BB%B4%E5%B0%94%EF%BC%8C%E6%88%91%E4%BC%9A%E6%94%AF%E6%8C%81%E6%82%A8%E7%9A%84%E6%A1%88%E4%BE%8B%EF%BC%8C%E8%AE%A9%E6%88%91%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E6%9D%A5%E6%B5%8B%E8%AF%95%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
