MCUXpresso for VSCode cannot run hello on MCXN947
marcocavallini
I am experimenting with MCXN947 using MCUXpresso for VSCode.
  • Build machine Ubuntu 22.04.
  • VSCode version 1.88.1
Installed the components using MCUXpresso Installer v.1.2
  • MCUXpresso SDK (2.14.0)
  • LinkServer
  • ARM GNU toolchain
  • Standalone toolchain addons
  • CMSIS toolbox
Then I followed the excellent guide Getting Started with MCUXpresso for Visual Studio Code by @kyledando
I am able to build frdmmcxn947_hello_world
The board is connected via USB-C cable (J17 MCU-LINK) to the PC (USB Port)
And detected as MCU-LINK FRDM-MCXN947
$ lsusb
Bus 001 Device 087: ID 1fc9:0143 NXP Semiconductors MCU-LINK FRDM-MCXN947 (r0E7) CMSIS-DAP V3.128
Unfortunately when I try to debug it I get popup message showing "Unable to start debugging. Debug server process failed to initialize".
The message pretends to open launch.json
  "configurations": [
      "type": "cppdbg",
      "name": "Debug project configuration",
      "request": "launch",
      "cwd": "${workspaceRoot}",
      "MIMode": "gdb",
      "setupCommands": [
        {"text": "set remotetimeout 600"},
        {"text": "set debug-file-directory"}
      "program": "",
      "miDebuggerServerAddress": "", // Remote GDB server address. If this is provided, "debugServerPath" will not be auto-completed.
      "variables": {
        "mcuxStopAtSymbol": "main", // Initial breakpoint
        "mcuxSerialNumber": "HU4NSCTMxxxxx", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxAttach": "false", // Start debug in attach mode
        "mcuxRemoteProbeType": "", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
        "mcuxSkipBuildWhenDebug": "false" // Skip build when debug
      "logging": {
        "engineLogging": false
At this point I'm stuck and I can't figure out how to proceed.
Any help would be appreciated.
nicu_manescu
Hi @marcocavallini,
The log does not contain relevant information. Additional info should be logged after:
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [read] Loading "LS_preconnect_MCXN9XX.scp"
[Warning] 1: (3221) STDERR: [2900]DEBUG:launcher.core.redlinkserv: [write] run
Could you please try an erase first. This worked in a similar situation (see previous replies).
Nicu
jwolinski
Hi @cristiantepus @Pavel_Hernandez I'm trying to run debug session in VSCode. I have similar setup, except I'm using Windows OS.
I have similar issue, this is my launch.json file:
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "D:\\vscode\\projects\\embedded\\frdm-mcxn947\\frdmmcxn947_led_blinky\\armgcc\\debug\\led_blinky.elf",
      "miDebuggerPath": "D:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin\\arm-none-eabi-gdb.exe",
      "miDebuggerArgs": "localhost:3333",
      "variables": {
        "mcuxSerialNumber": "JUSOLFVVYXBVB", // Probe serial number. If not specified, the one from the selected debug probe (in extension view) will be used.
        "mcuxRemoteProbeType": "LinkServer", // Remote Probe Type ("LinkServer", "SEGGER", "PEmicro") used only when connecting to a remote server
      "logging": {
        "engineLogging": true
cristiantepus
Hi @jwolinski ,
Can you please try an erase first (right click on project + erase, or, go to QuickStart Panel -> Flash Programmer -> Erase) then a debug again? Does this solve your connectivity issue?
Cristian
jwolinski
Hi @cristiantepus, yes I think this was a problem.
Pavel_Hernandez
Hello, sorry for the late response, I tried on mi Linux PC and at the first time have the same issue but then the VSCODE detect the board and I will start the Debug session.
"configurations": [
"type": "cppdbg",
"MIMode": "gdb",
"setupCommands": [
"program": "",
"variables": {
"mcuxSerialNumber": "WLEDDEPSMN35Q",
"logging": {
"name": "C/C++: gcc-11 build and debug active file",
"type": "cppdbg",
"program": "${fileDirname}/${fileBasenameNoExtension}",
"args": [],
"stopAtEntry": false,
"cwd": "${fileDirname}",
"environment": [],
"externalConsole": false,
"MIMode": "gdb",
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"description": "Set Disassembly Flavor to Intel",
"text": "-gdb-set disassembly-flavor intel",
"preLaunchTask": "C/C++: gcc-11 build active file",
"miDebuggerPath": "/usr/bin/gdb","variables": {"mcuxSerialNumber":"WLEDDEPSMN35Q"}
"version": "2.0.0"
Look the differences from your JSON.
Let me know about the status of your issue.
Pavel
jwolinski
Hello, no problem. For me the issue was solved right after I specifed Flash Programmer to Link Server in this window:
After that i flashed the board and finally I could start debug session, however I'm wondering why it was working because some fileds in json file like program,  was not specified.
  "configurations": [
      "type": "cppdbg",
      "MIMode": "gdb",
      "setupCommands": [
      "program": "",
      "miDebuggerArgs": "",
      "variables": {
      "logging": {
Thanks for your anwser!
cristiantepus
Can you please make enableLogging as true in your launch config, debug once again and attach here the log?
Cristian
marcocavallini
Hi @cristiantepus
Sorry for the late reply.
Please find the attached build-log.txt file
nicu_manescu
Hi @marcocavallini,
Nicu
marcocavallini
@nicu_manescu
erasing flash prior to start debugging solved the issue. Now it works!
Thank you
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information testing this.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1849077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849077%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20experimenting%20with%20%3CSTRONG%3EMCXN947%3C%2FSTRONG%3E%20using%20%3CSTRONG%3EMCUXpresso%20for%20VSCode%3C%2FSTRONG%3E.%3C%2FP%3E%3CUL%3E%3CLI%3EBuild%20machine%20%3CSTRONG%3EUbuntu%2022.04%3C%2FSTRONG%3E.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EVSCode%3C%2FSTRONG%3E%20version%20%3CSTRONG%3E1.88.1%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EInstalled%20the%20components%20using%20%3CSTRONG%3EMCUXpresso%20Installer%20v.1.2%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3EMCUXpresso%20SDK%20(2.14.0)%3C%2FLI%3E%3CLI%3ELinkServer%3C%2FLI%3E%3CLI%3EARM%20GNU%20toolchain%3C%2FLI%3E%3CLI%3EStandalone%20toolchain%20addons%3C%2FLI%3E%3CLI%3ECMSIS%20toolbox%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThen%20I%20followed%20the%20excellent%20guide%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Ftraining%2Fgetting-started-with-mcuxpresso-for-visual-studio-code%3ATIP-GETTING-STARTED-WITH-MCUXPRESSO-FOR-VS-CODE%3FSAMLart%3DST-AAF0E3YJDJej%252BJVBprc7Vu5rkUdezz2Xd17s%252F27bgltNLOpmAEfiv3wm%23colkp5maoqd%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGetting%20Started%20with%20MCUXpresso%20for%20Visual%20Studio%20Code%3C%2FA%3E%20by%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F193716%22%20target%3D%22_blank%22%3E%40kyledando%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20able%20to%20build%20%3CSTRONG%3Efrdmmcxn947_hello_world%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EThe%20board%20is%20connected%20via%20USB-C%20cable%20(J17%20MCU-LINK)%20to%20the%20PC%20(USB%20Port)%3C%2FP%3E%3CP%3EAnd%20detected%20as%20MCU-LINK%20FRDM-MCXN947%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%24%20lsusb%0ABus%20001%20Device%20087%3A%20ID%201fc9%3A0143%20NXP%20Semiconductors%20MCU-LINK%20FRDM-MCXN947%20(r0E7)%20CMSIS-DAP%20V3.128%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EUnfortunately%20when%20I%20try%20to%20debug%20it%20I%20get%20popup%20message%20showing%20%22Unable%20to%20start%20debugging.%20Debug%20server%20process%20failed%20to%20initialize%22.%3C%2FP%3E%3CP%3EThe%20message%20pretends%20to%20open%20%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-java%22%3E%3CCODE%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22miDebuggerServerAddress%22%3A%20%22%22%2C%20%2F%2F%20Remote%20GDB%20server%20address.%20If%20this%20is%20provided%2C%20%22debugServerPath%22%20will%20not%20be%20auto-completed.%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22HU4NSCTMxxxxx%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20false%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EAt%20this%20point%20I'm%20stuck%20and%20I%20can't%20figure%20out%20how%20to%20proceed.%3C%2FP%3E%3CP%3EAny%20help%20would%20be%20appreciated.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24047%22%20target%3D%22_blank%22%3E%40nicu_manescu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3Eerasing%20flash%20prior%20to%20start%20debugging%20solved%20the%20issue.%20Now%20it%20works!%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F6688%22%20target%3D%22_blank%22%3E%40marcocavallini%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThe%20log%20does%20not%20contain%20relevant%20information.%20Additional%20info%20should%20be%20logged%20after%3A%3CBR%20%2F%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%3E%3CFONT%20face%3D%22terminal%2Cmonaco%22%3E%5BWarning%5D%201%3A%20(3221)%20STDERR%3A%20%5B2900%5DDEBUG%3Alauncher.core.redlinkserv%3A%20%5Bread%5D%20Loading%20%22LS_preconnect_MCXN9XX.scp%22%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22terminal%2Cmonaco%22%3E%5BWarning%5D%201%3A%20(3221)%20STDERR%3A%20%5B2900%5DDEBUG%3Alauncher.core.redlinkserv%3A%20%5Bwrite%5D%20run%3C%2FFONT%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%3ECould%20you%20please%20try%20an%20erase%20first.%20This%20worked%20in%20a%20similar%20situation%20(see%20previous%20replies).%3C%2FP%3E%0A%3CP%3EThanks%2C%3C%2FP%3E%0A%3CP%3ENicu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3ESorry%20for%20the%20late%20reply.%3CBR%20%2F%3EPlease%20find%20the%20attached%20%3CSTRONG%3Ebuild-log.txt%3C%2FSTRONG%3E%20file%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%2C%20yes%20I%20think%20this%20was%20a%20problem.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20no%20problem.%20For%20me%20the%20issue%20was%20solved%20right%20after%20I%20specifed%20Flash%20Programmer%20to%20Link%20Server%20in%20this%20window%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_1-1714026113557.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_1-1714026113557.png%22%20style%3D%22width%3A%20311px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275767iBD0480A684FCD5CB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_1-1714026113557.png%22%20alt%3D%22jwolinski_1-1714026113557.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_0-1714025888403.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_0-1714025888403.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275765iCF5B3386EBC0E27C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_0-1714025888403.png%22%20alt%3D%22jwolinski_0-1714025888403.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAfter%20that%20i%20flashed%20the%20board%20and%20finally%20I%20could%20start%20debug%20session%2C%20however%20I'm%20wondering%20why%20it%20was%20working%20because%20some%20fileds%20in%20json%20file%20like%20%3CSTRONG%3Eprogram%2C%26nbsp%3B%3C%2FSTRONG%3E%20was%20not%20specified.%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22miDebuggerArgs%22%3A%20%22%22%2C%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22JUSOLFVVYXBVB%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22LinkServer%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20true%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EThanks%20for%20your%20anwser!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232678%22%20target%3D%22_blank%22%3E%40jwolinski%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3ECan%20you%20please%20try%20an%20erase%20first%20(right%20click%20on%20project%20%2B%20erase%2C%20or%2C%20go%20to%20QuickStart%20Panel%20-%26gt%3B%20Flash%20Programmer%20-%26gt%3B%20Erase)%20then%20a%20debug%20again%3F%20Does%20this%20solve%20your%20connectivity%20issue%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ECristian%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1854243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1854243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20sorry%20for%20the%20late%20response%2C%20I%20tried%20on%20mi%20Linux%20PC%20and%20at%20the%20first%20time%20have%20the%20same%20issue%20but%20then%20the%20VSCODE%20detect%20the%20board%20and%20I%20will%20start%20the%20Debug%20session.%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%7B%0A%22configurations%22%3A%20%5B%0A%7B%0A%22type%22%3A%20%22cppdbg%22%2C%0A%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%22request%22%3A%20%22launch%22%2C%0A%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%22MIMode%22%3A%20%22gdb%22%2C%0A%22setupCommands%22%3A%20%5B%0A%7B%0A%22text%22%3A%20%22set%20remotetimeout%20600%22%0A%7D%2C%0A%7B%0A%22text%22%3A%20%22set%20debug-file-directory%22%0A%7D%0A%5D%2C%0A%22program%22%3A%20%22%22%2C%0A%22miDebuggerServerAddress%22%3A%20%22%22%2C%0A%22variables%22%3A%20%7B%0A%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%0A%22mcuxSerialNumber%22%3A%20%22WLEDDEPSMN35Q%22%2C%0A%22mcuxAttach%22%3A%20%22false%22%2C%0A%22mcuxRemoteProbeType%22%3A%20%22%22%2C%0A%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%0A%7D%2C%0A%22logging%22%3A%20%7B%0A%22engineLogging%22%3A%20false%0A%7D%0A%7D%2C%0A%7B%0A%22name%22%3A%20%22C%2FC%2B%2B%3A%20gcc-11%20build%20and%20debug%20active%20file%22%2C%0A%22type%22%3A%20%22cppdbg%22%2C%0A%22request%22%3A%20%22launch%22%2C%0A%22program%22%3A%20%22%24%7BfileDirname%7D%2F%24%7BfileBasenameNoExtension%7D%22%2C%0A%22args%22%3A%20%5B%5D%2C%0A%22stopAtEntry%22%3A%20false%2C%0A%22cwd%22%3A%20%22%24%7BfileDirname%7D%22%2C%0A%22environment%22%3A%20%5B%5D%2C%0A%22externalConsole%22%3A%20false%2C%0A%22MIMode%22%3A%20%22gdb%22%2C%0A%22setupCommands%22%3A%20%5B%0A%7B%0A%22description%22%3A%20%22Enable%20pretty-printing%20for%20gdb%22%2C%0A%22text%22%3A%20%22-enable-pretty-printing%22%2C%0A%22ignoreFailures%22%3A%20true%0A%7D%2C%0A%7B%0A%22description%22%3A%20%22Set%20Disassembly%20Flavor%20to%20Intel%22%2C%0A%22text%22%3A%20%22-gdb-set%20disassembly-flavor%20intel%22%2C%0A%22ignoreFailures%22%3A%20true%0A%7D%0A%5D%2C%0A%22preLaunchTask%22%3A%20%22C%2FC%2B%2B%3A%20gcc-11%20build%20active%20file%22%2C%0A%22miDebuggerPath%22%3A%20%22%2Fusr%2Fbin%2Fgdb%22%2C%22variables%22%3A%20%7B%22mcuxSerialNumber%22%3A%22WLEDDEPSMN35Q%22%7D%0A%7D%0A%5D%2C%0A%22version%22%3A%20%222.0.0%22%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3ELook%20the%20differences%20from%20your%20JSON.%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20about%20the%20status%20of%20your%20issue.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1853419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1853419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F169601%22%20target%3D%22_blank%22%3E%40cristiantepus%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196430%22%20target%3D%22_blank%22%3E%40Pavel_Hernandez%3C%2FA%3E%26nbsp%3BI'm%20trying%20to%20run%20debug%20session%20in%20VSCode.%20I%20have%20similar%20setup%2C%20except%20I'm%20using%20Windows%20OS.%3C%2FP%3E%3CP%3EI%20have%20similar%20issue%2C%20this%20is%20my%20%3CSTRONG%3Elaunch.json%3C%2FSTRONG%3E%20file%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%3E%7B%0A%20%20%22configurations%22%3A%20%5B%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%22type%22%3A%20%22cppdbg%22%2C%0A%20%20%20%20%20%20%22name%22%3A%20%22Debug%20project%20configuration%22%2C%0A%20%20%20%20%20%20%22request%22%3A%20%22launch%22%2C%0A%20%20%20%20%20%20%22cwd%22%3A%20%22%24%7BworkspaceRoot%7D%22%2C%0A%20%20%20%20%20%20%22MIMode%22%3A%20%22gdb%22%2C%0A%20%20%20%20%20%20%22setupCommands%22%3A%20%5B%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20remotetimeout%20600%22%7D%2C%0A%20%20%20%20%20%20%20%20%7B%22text%22%3A%20%22set%20debug-file-directory%22%7D%0A%20%20%20%20%20%20%5D%2C%0A%20%20%20%20%20%20%22program%22%3A%20%22D%3A%5C%5Cvscode%5C%5Cprojects%5C%5Cembedded%5C%5Cfrdm-mcxn947%5C%5Cfrdmmcxn947_led_blinky%5C%5Carmgcc%5C%5Cdebug%5C%5Cled_blinky.elf%22%2C%0A%20%20%20%20%20%20%22miDebuggerPath%22%3A%20%22D%3A%5C%5CProgram%20Files%20(x86)%5C%5CGNU%20Arm%20Embedded%20Toolchain%5C%5C10%202021.10%5C%5Cbin%5C%5Carm-none-eabi-gdb.exe%22%2C%0A%20%20%20%20%20%20%22miDebuggerArgs%22%3A%20%22localhost%3A3333%22%2C%0A%20%20%20%20%20%20%22variables%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22mcuxStopAtSymbol%22%3A%20%22main%22%2C%20%2F%2F%20Initial%20breakpoint%0A%20%20%20%20%20%20%20%20%22mcuxSerialNumber%22%3A%20%22JUSOLFVVYXBVB%22%2C%20%2F%2F%20Probe%20serial%20number.%20If%20not%20specified%2C%20the%20one%20from%20the%20selected%20debug%20probe%20(in%20extension%20view)%20will%20be%20used.%0A%20%20%20%20%20%20%20%20%22mcuxAttach%22%3A%20%22false%22%2C%20%2F%2F%20Start%20debug%20in%20attach%20mode%0A%20%20%20%20%20%20%20%20%22mcuxRemoteProbeType%22%3A%20%22LinkServer%22%2C%20%2F%2F%20Remote%20Probe%20Type%20(%22LinkServer%22%2C%20%22SEGGER%22%2C%20%22PEmicro%22)%20used%20only%20when%20connecting%20to%20a%20remote%20server%0A%20%20%20%20%20%20%20%20%22mcuxSkipBuildWhenDebug%22%3A%20%22false%22%20%2F%2F%20Skip%20build%20when%20debug%0A%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%22logging%22%3A%20%7B%0A%20%20%20%20%20%20%20%20%22engineLogging%22%3A%20true%0A%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%5D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jwolinski_0-1713958589547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jwolinski_0-1713958589547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F275545i7A5706CF7DB13185%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jwolinski_0-1713958589547.png%22%20alt%3D%22jwolinski_0-1713958589547.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1851231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1851231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3ECan%20you%20please%20make%20enableLogging%20as%20true%20in%20your%20launch%20config%2C%20debug%20once%20again%20and%20attach%20here%20the%20log%3F%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ECristian%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1849382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20for%20VSCode%20cannot%20run%20hello%20on%20MCXN947%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1849382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20my%20name%20is%20Pavel%2C%20and%20I%20will%20be%20supporting%20your%20case%2C%20let%20me%20get%20more%20information%20testing%20this.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
