Change JLink GDB server speed MCUXPRESSO-VSC
Maximvda
Dear Support,
I was wondering if there is a possibility to configure the programming/flash speed of the JLink debugger. Currently, it is fixed to 4000 but I can't seem to find any settings to change this.
A higher speed could greatly increase our productivity as programming the device is starting to get longer and longer the more our project grows.
Kind regards,
Maxim
ErichStyger
Specialist I
Hi @Maximvda ,
this is how I did it:
I hope this helps,
Erich
ErichStyger
Specialist I
Hi @Maximvda ,
I hope this helps,
Erich
Maximvda
We are not using the rtos plugin but by pointing it to a useless directory I got it working.
Example: "mcuxSeggerRTOSPlugin": ".vscode -speed 8000",
Pavel_Hernandez
Hello, I have reviewed your information and maybe the J-Link commander tool helps you, this has the possibility to change the speed.
Pavel
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
