Dear Support,
I was wondering if there is a possibility to configure the programming/flash speed of the JLink debugger. Currently, it is fixed to 4000 but I can't seem to find any settings to change this.
A higher speed could greatly increase our productivity as programming the device is starting to get longer and longer the more our project grows.
Kind regards,
Maxim
Solved! Go to Solution.
Hello, I have reviewed your information and maybe the J-Link commander tool helps you, this has the possibility to change the speed.
Pavel
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
