MCUXpresso Secure Provisioning Tool v4.0.1 not run
ソリューションへジャンプ
4,347件の閲覧回数
Aurelien_Grange
I install version V4.0.1 of MCUXpresso Secure Provisioning Tool to check if I can made some test whitouth brick the MCU.
Install  works on windows but application doesn't run.
I try to reinstall but issue is still here.
Application return
and after nothing.
I run Windows 10 Professionnal
How Can i run this application?
Have a good days
4,333件の閲覧回数
liborukropec
Hi Aurelien,
I'd like to continue in this thread, where it should belong.
I try to change regionnal parameter to USA/English but it's not working.
With -v i've got the following issue :
INFO: [root] workspace C:\Users\User\secure_provisioning
WARNING: [root] Loading settings from workspace: Settings loaded successfuly
Traceback (most recent call last):
File "securep.py", line 64, in <module>
You probably had previous SEC version installed and from some reason the settings is not compatible. Please try to rename (to not lose your settings and data) the folder `C:\Users\User\secure_provisioning` to e.g. `C:\Users\User\secure_provisioning_old` and then execute the SEC tool.
Libor
5 返答(返信)
4,354件の閲覧回数
Aurelien_Grange
File "securep.py", line 36, in main
File "securep.py", line 59, in main_run
File "src\gui\main\main_win_ctrl.py", line 667, in run_gui
File "src\gui\main\main_win_ctrl.py", line 65, in __init__
File "src\gui\main\main_win_toolbar.py", line 47, in __init__
File "src\gui\main\main_win_keys.py", line 90, in __init__
File "src\gui\main\main_win_build.py", line 87, in __init__
File "src\gui\main\main_win_build.py", line 730, in update_key_choice_selection
File "src\logic\build\build_image_config_impl.py", line 474, in sb_build_key
File "src\logic\usr_config\keys_management_config.py", line 431, in get_key_by_id
File "src\logic\usr_config\keys_management_config.py", line 404, in _get_keys
File "src\logic\usr_config\keys_management_config.py", line 521, in new_rot_cfg
File "<string>", line 6, in __init__
File "src\logic\usr_config\keys_management_config.py", line 47, in __post_init__
File "src\logic\usr_config\keys_management_config.py", line 145, in index
ValueError: Key filename in unexpected format, does not match expected regular expression
[1572] Failed to execute script 'securep' due to unhandled exception!
4,334件の閲覧回数
liborukropec
Hi Aurelien,
Libor
4,332件の閲覧回数
Aurelien_Grange
Hi thaks it works
I hope next version can create automaticaly a new folder to avoid this issue.
Have a good day.
4,327件の閲覧回数
marek-trmac
Hi Aurelien,
thanks for reporting the issue and we apologies for inconvenience. This is not known issue.
Based on your stack trace logged to different issue
It seems the problems is in the keys folder. You probably have there some unrecognized file. Could you send us list of files from keys\ and certs\ subfolders from your workspace (just file names)? Could you also let us know, what is target processor in your workspace? We'd like reproduce the issue and fix for next release.
We'd like to keep the tool backward compatible, so workspace from previous version could be loaded in new version too.
Thanks for your help
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
4,335件の閲覧回数
liborukropec
Hi Aurelien,
could you please launch the SEC tool in the Command prompt
C:\nxp\MCUX_Provi_v4\bin>securep.exe -v
So we can see the error message?
Also you might try to switch to English US locale, see https://community.nxp.com/t5/MCUXpresso-Secure-Provisioning/Can-t-open-SPT-v3-1-after-installation-o...
Libor
