Fail to install due to older version of Microsoft Visual C++ distribution version
2,748 次查看
VicKrawciw
I cannot install SPT due to the Microsoft Visual C++ distribution requirement being older than the one I currently have installed. How can I resolve this?
4 回复数
2,727 次查看
VicKrawciw
Thank you - yes that worked.
2,719 次查看
liborukropec
Hi Victor,
glad to hear, workaround worked. We have found issue in v5 installer detecting what MSVC++ version is installed. Also we have found (another) reliable a workaround, that might help other users.
The order of actions is important:
  1. Download SEC v4.1.1
  2. Download SEC v5
  3. Install SEC v5 - it fails, but required MSVC++ for run is installed
  4. Install SEC v4.1.1- it installs MSVC++ that is needed only to satisfy v5 installer
  5. Install SEC v5 - it skips MSVC++ installation because satisfied by previous step
  6. SEC v4.1.1 can be uninstalled
Libor
2,734 次查看
marek-trmac
Hi Victor,
see also chapter 9. Troubleshooting in User Guide, there is link to the problem resolution at MSDN forum. Unfortunately, it seems there is not simple solutions for all configurations.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
2,736 次查看
liborukropec
Hi Victor,
workaround posted here does not work for you?
https://community.nxp.com/t5/MCUXpresso-Secure-Provisioning/Secure-Provisioning-Tool-V5-b220825/td-p...
Libor
