wrong macro check in some files
386件の閲覧回数
mastupristi
Senior Contributor I
I refer to SDK 25.06.00.
My projects can use FreeRTOS or be bare metal.
So I can have the USE_RTOS symbol defined as 0 or 1.
And this is generally fine because when the check is done, it is usually:
#if (defined(USE_RTOS) && (USE_RTOS > 0U))
see https://github.com/nxp-mcuxpresso/mcux-component/blob/main/lists/fsl_component_generic_list.c#L17
or https://github.com/nxp-mcuxpresso/mcux-component/blob/main/mem_manager/fsl_component_mem_manager.c#L...
So, as I already mentioned in my bare metal projects, I feel free to set USE_RTOS to 0.
In the fsl_os_abstraction.h file itself, there is this define under certain conditions:
https://github.com/nxp-mcuxpresso/mcux-component/blob/main/osa/fsl_os_abstraction.h#L194
However, there are some files released by NXP that do not follow this paradigm, for example ./middleware/mcuboot_opensource/boot/nxp_mcux_sdk/include/os/os_malloc.h
where the check is simply:
#if defined(USE_RTOS)
https://github.com/nxp-mcuxpresso/mcuboot/blob/mcux_main/boot/nxp_mcux_sdk/include/os/os_malloc.h#L2...
Obviously, this check is not valid if USE_RTOS is defined as 0 in order to disable the functionality.
This is not the only example.
I would ask you to review your entire code base and fix this problem.
best regards
Max
371件の閲覧回数
danielchen
Hi @mastupristi
 Yes, you are right.  This is a known issue and I will forward it to  the software team .
Thanks a lot for your feedback.
372件の閲覧回数
danielchen
Hi @mastupristi
%3CLINGO-SUB%20id%3D%22lingo-sub-2166550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%80%E9%83%A8%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%83%9E%E3%82%AF%E3%83%AD%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166550%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3ESDK%2025.06.00%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%20FreeRTOS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%80%81%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82CAN%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EUSE_RTOS%3C%2FFONT%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%200%20%E3%81%BE%E3%81%9F%E3%81%AF%201%20%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E9%80%9A%E5%B8%B8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23if%20(defined(USE_RTOS)%20%26amp%3B%26amp%3B%20(USE_RTOS%20%26gt%3B%200U))%3C%2FPRE%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Flists%2Ffsl_component_generic_list.c%23L17%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Flists%2Ffsl_component_generic_list.c%23L17%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Fmem_manager%2Ffsl_component_mem_manager.c%23L20%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Fmem_manager%2Ffsl_component_mem_manager.c%23L20%3C%2FA%3E%3C%2FP%3E%3CP%3ESO%E3%80%81%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%99%E3%81%A7%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EUSE_RTOS%20%E3%82%92%3C%2FFONT%3E0%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efsl_os_abstraction.h%3C%2FFONT%3E%E5%86%85%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%87%AA%E4%BD%93%E3%81%AB%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E6%9D%A1%E4%BB%B6%E4%B8%8B%E3%81%A7%E3%81%AE%E3%81%93%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Fosa%2Ffsl_os_abstraction.h%23L194%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcux-component%2Fblob%2Fmain%2Fosa%2Ffsl_os_abstraction.h%23L194%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81NXP%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%B8%AD%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%A9%E3%83%80%E3%82%A4%E3%83%A0%E3%81%AB%E5%BE%93%E3%82%8F%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%80%81%2Fmiddleware%2Fmcuboot_opensource%2F%3C%2FFONT%3E%20boot%2Fnxp_mcux_sdk%2Finclude%2Fos%2Fos_malloc.h%20%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AE%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E5%8D%98%E7%B4%94%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23if%20defined(USE_RTOS)%3C%2FPRE%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcuboot%2Fblob%2Fmcux_main%2Fboot%2Fnxp_mcux_sdk%2Finclude%2Fos%2Fos_malloc.h%23L23%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fmcuboot%2Fblob%2Fmcux_main%2Fboot%2Fnxp_mcux_sdk%2Finclude%2Fos%2Fos_malloc.h%23L23%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%80%81%E6%A9%9F%E8%83%BD%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20USE_RTOS%20%E3%81%8C%200%20%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%94%AF%E4%B8%80%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%99%E3%83%BC%E3%82%B9%E5%85%A8%E4%BD%93%E3%82%92%E8%A6%8B%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%82%88%E3%81%86%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20wrong%20macro%20check%20in%20some%20files%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
