no Usb stack in build SDK2.2 for MKL26Z128
1,565 次查看
enore_grattoni
in MCUXPRESSO build for MKL26Z128VFT4 with selection FatFS, USB stack, FreeRTOS as middleware there is not USB stack. I am sure because I did same selection for KSDK 2.0.
In folder KSDK2.0/boards/frdmkl26z   there is usb_example folder (together with other folders)
in folder SDK_2.2_MKL26Z128xxx4/boards/frdmkl26z there is not usb_example folder (together with other folders).
1,478 次查看
Lukas_Heczko
Hi Enore,
I tried to generate and download MKL26Z128xxx4 package and in boards\frdmkl26z I see usb_examples directory. Can you please share details about SDK configuration (including the Package hash) related to your SDK package? You can find it under MANAGE > SDK Archive:
Thank you,
Lukas
