Hi all, I need to build a TCP echo server application using the lwip libraries.
I use i.MX RT1064 Evaluation Kit and MCUxpresso.
I started with the evkmimxrt1064_lwip_tcpecho_bm and evkmimxrt1064_lwip_tcpecho_freertos SDK examples. Perfect and working. But the _bm version, which uses the RAW API, is 30 times faster.
I tried to merge the two projects.
The idea is to have FreeRTOS and dedicate a task to LwIP and the TCP server working with callbacks.
I could not. Anyone have a working basic example?
Gionatha
