The example echoes any character typed in by the user. However, I am looking for a way to write to the virtual com port using PRINTF(); function (Or any other alternative).
Is there a way to redirect PRINTF(); to USB VCOM?
Solved! Go to Solution.
Hi @CarrotMan ,
usb_device_cdc_vcom_lite will simulate the USB port as the vcom,then printf the data through the USB VCOM.
You can use: usb_echo("kerry test");
#define usb_echo DbgConsole_Printf
The usb_echo will printf the data to the board debug COM.
The USB VCOM mainly use the USB_DeviceSendRequest to send the data out.
So, you still can use the USB_DeviceSendRequest API to send out it. You can see, the USB need the handler, the endpoint, the buffer and size, not just simple printf.
Wish it helps you!
Kerry
Hi @CarrotMan ,
Wish it helps you!
Kerry
