emWin drivers missing
Search instead for
randylee
so I"m trying to use emWin in MCUexpresso using SDK 2.4.1 and it's there with a certain number of drivers as far as I can tell.
However, there are a number of drivers listed in the Segger documentation for that revision (5.38) that don't appear as .h files in the code tree when emWin is added to the project
In particular I"m looking for GUIDRV_6331
Is this oversight on the SDK side or is there some limitation in the license model from Segger?
Tags (2)
jeremyzhou
Hi RANDY LEE,
I was wondering if you can tell me which MCU's SDK you build, I'd like to check it by myself at first and I'll reply you later.
TIC
randylee
Not sure I'm clear on what you want to know.  This is using SDK 2.4.1 on MK22FN512XXX12 parts.  Does that cover it?
