Wi-Fi promiscuous mode support
345 次查看
azarubkin
Does MCUXpresso SDK support promiscuous mode for Wi-Fi cards?
I currently use M.2 card based on IW416 chip (U-Blox Maya-W1), but I'm open to your suggestions.
I'm building a Wi-Fi/Ethernet network bridge -- if I understand correctly, I need to put the wireless card into promiscuous mode for that.
标记 (3)
300 次查看
RomanVR
Hello @azarubkin
Hope you are doing well. You can check all the currently supported features for our WiFi combos with MCUXpresso SDK within the following page: https://mcuxpresso.nxp.com/mcuxsdk/25.06.00/html/middleware/wireless/WiFi-Bluetooth-802.15.4/rnindex...
Also, I would recommend refering to the specific section of IW416.
Hope this helps!
Best Regards!
