What console is the default PRINTF line in projects printing to?
1,331 次查看
MelonM
Hello, I've just started using MCUXpresso, so I'm sorry if this question has an obvious answer.
When I use the SDK Wizard to create a project for my board (FRDM-KL25Z) using the default settings, the main function always contains the line:
PRINTF("Hello World\n");
 I need to do some debugging and this function seems useful for that purpose, but I can't figure out what console this function is printing to.
1,250 次查看
Pavel_Hernandez
Hello, I suggest reviewing the device COM available on the device manager then you need to use software to see the message like tera term or other.
Let me know if you have more doubts.
Pavel
1,251 次查看
Pavel_Hernandez
Pavel
