Update MKL27Z4 SAI Initialization calls
1,028件の閲覧回数
atsantilis
I am trying to update the initialization code for my MKL27Z256xxx4's SAI-over-DMA interface to use SDK v2.8.0. I am having a bit of trouble because the new SDK calls seem to use different data structures and I am struggling to translate them over. I am mainly using MCUXpresso's Config Tools to generate the new initialization calls.
According to the MCUXpresso project the old code was based off SDK 2.4.1 and looks like the following:
    /* Init DMAMUX */
    /* Channel 1 is I2S Transmit
     * Channel 0 is I2S Receive
    DMAMUX_Init(DMAMUX0);
    DMAMUX_SetSource(DMAMUX0, 0, 14);  //Map I2S RX to channel 0
    DMAMUX_SetSource(DMAMUX0, 1, 15);  //MAP I2S TX to channel 1
    DMAMUX_EnableChannel(DMAMUX0, 0);
    DMAMUX_EnableChannel(DMAMUX0, 1);
    /* Init DMA and create handle for DMA */
    DMA_Init(DMA0);
    DMA_CreateHandle(&dmaRxHandle, DMA0, 0);
    DMA_CreateHandle(&dmaTxHandle, DMA0, 1);
	// Setup the I2S interface
    SAI_TxGetDefaultConfig(&user_config);
    user_config.protocol = kSAI_BusI2S;
    user_config.syncMode = kSAI_ModeSync;
    user_config.mclkOutputEnable = false;
    user_config.masterSlave = kSAI_Slave;
    SAI_TxInit(I2S0, &user_config);
    SAI_RxInit(I2S0, &user_config);
    g_SAI_format.bitWidth = kSAI_WordWidth16bits;
    g_SAI_format.channel = 0;
    g_SAI_format.protocol = kSAI_BusI2S;
    g_SAI_format.sampleRate_Hz = kSAI_SampleRate48KHz;
    g_SAI_format.stereo = kSAI_Stereo;
	SAI_TransferTxCreateHandleDMA(I2S0, &g_m_tx_dma_handle, AudioBufferHandler_DMATxCallback, NULL, &dmaTxHandle);
	SAI_TransferTxSetFormatDMA(I2S0,
                               &g_m_tx_dma_handle,
	    					   &g_SAI_format,
							   CLOCK_GetFreq(kCLOCK_CoreSysClk),
							   12288000U);
	// We are running a Mono Mic
	g_SAI_format.stereo = kSAI_MonoLeft;
	SAI_TransferRxCreateHandleDMA(I2S0, &g_m_rx_dma_handle, AudioBufferHandler_DMARxCallback, NULL, &dmaRxHandle);
	SAI_TransferRxSetFormatDMA(I2S0,
                               &g_m_rx_dma_handle,
							   &g_SAI_format,
							   12288000U);
Here is what the IDE generated:
 * I2S0 initialization code
/* clang-format off */
/* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
instance:
- name: 'I2S0'
- type: 'sai'
- mode: 'dma'
- custom_name_enabled: 'false'
- type_id: 'sai_37a0d4b4ecc2db8ea149dbe2026c6550'
- functional_group: 'BOARD_InitPeripherals'
- peripheral: 'I2S0'
- config_sets:
  - fsl_sai:
    - mclk_config:
      - masterClockSource: 'ExternalClock'
      - masterClockFrequency: '12.288 MHz'
      - init_mclk_config: 'true'
    - sai_master_clock: []
    - usage: 'record_playback'
    - signal_config:
      - 0:
        - sourceTx: 'Tx'
        - sourceRx: 'Rx'
      - 1:
        - sourceTx: 'Tx'
        - sourceRx: 'Rx'
    - syncSwapI: []
    - bclkTxSetting: []
    - bclkRxSetting: []
    - syncTxSetting: []
    - syncRxSetting: []
    - whole:
      - tx_group:
        - sai_transceiver:
          - bitClock:
            - modeM: 'slave'
            - slaveBitClockFrequency: '12.288MHz'
            - bitClockSource: 'kSAI_BclkSourceMclkDiv'
            - bclkPolarityM: 'kSAI_PolarityActiveLow'
            - bclkInputDelayM: 'false'
          - frameSync:
            - modeM: 'slave'
            - frameSyncWidthM: '16'
            - frameSyncPolarityM: 'kSAI_PolarityActiveLow'
            - frameSyncEarlyM: 'true'
          - sampleRate_Hz: 'kSAI_SampleRate48KHz'
          - channelMask: 'kSAI_Channel0Mask'
          - serialData:
            - differentFirstWord: 'false'
            - sameDataWordLengthM: 'kSAI_WordWidth16bits'
            - dataOrder: 'kSAI_DataMSB'
            - dataFirstBitShiftedM: '16'
            - dataWordNumM: '2'
            - dataMasked_config:
              - dataMasked_L:
                - 0: 'false'
                - 1: 'false'
                - 2: 'false'
                - 3: 'false'
                - 4: 'false'
                - 5: 'false'
                - 6: 'false'
                - 7: 'false'
                - 8: 'false'
                - 9: 'false'
                - 10: 'false'
                - 11: 'false'
                - 12: 'false'
                - 13: 'false'
                - 14: 'false'
                - 15: 'false'
              - dataMasked_H:
                - 0: 'false'
                - 1: 'false'
                - 2: 'false'
                - 3: 'false'
                - 4: 'false'
                - 5: 'false'
                - 6: 'false'
                - 7: 'false'
                - 8: 'false'
                - 9: 'false'
                - 10: 'false'
                - 11: 'false'
                - 12: 'false'
                - 13: 'false'
                - 14: 'false'
                - 15: 'false'
          - fifo:
            - fifoPacking: 'kSAI_FifoPackingDisabled'
            - fifoContinueOneError: 'false'
        - dma_group:
          - enable_dma_channel: 'true'
          - dma_channel:
            - DMAn: '1'
            - DMA_source: 'kDmaRequestMux0I2S0Tx'
            - enableTriggerPIT: 'false'
            - enable_custom_name: 'true'
            - handle_custom_name: 'dmaTxHandle'
          - sai_dma_handle:
            - handle_custom_name: 'g_m_tx_dma_handle'
            - init_callback: 'true'
            - callback_fcn: 'AudioBufferHandler_DMATxCallback'
            - user_data: ''
      - rx_group:
        - sai_transceiver:
          - bitClock:
            - modeM: 'slave'
          - frameSync:
            - modeM: 'slave'
          - serialData:
            - dataWordNumM: '2'
              - dataMasked_L:
                - 0: 'false'
                - 1: 'false'
                - 2: 'false'
                - 3: 'false'
                - 4: 'false'
                - 5: 'false'
                - 6: 'false'
                - 7: 'false'
                - 8: 'false'
                - 9: 'false'
                - 10: 'false'
                - 11: 'false'
                - 12: 'false'
                - 13: 'false'
                - 14: 'false'
                - 15: 'false'
              - dataMasked_H:
                - 0: 'false'
                - 1: 'false'
                - 2: 'false'
                - 3: 'false'
                - 4: 'false'
                - 5: 'false'
                - 6: 'false'
                - 7: 'false'
                - 8: 'false'
                - 9: 'false'
                - 10: 'false'
                - 11: 'false'
                - 12: 'false'
                - 13: 'false'
                - 14: 'false'
                - 15: 'false'
          - fifo:
        - dma_group:
          - dma_channel:
            - DMAn: '0'
            - DMA_source: 'kDmaRequestMux0I2S0Rx'
            - handle_custom_name: 'dmaRxHandle'
          - sai_dma_handle:
            - handle_custom_name: 'g_m_rx_dma_handle'
            - callback_fcn: 'AudioBufferHandler_DMARxCallback'
            - user_data: ''
 * BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
/* clang-format on */
/* I2S0 Tx configuration */
sai_transceiver_t I2S0_Tx_config = {
  .masterSlave = kSAI_Slave,
  .bitClock = {
    .bclkSrcSwap = false,
    .bclkSource = kSAI_BclkSourceMclkDiv,
    .bclkPolarity = kSAI_PolarityActiveLow,
    .bclkInputDelay = false
  .frameSync = {
    .frameSyncWidth = 16U,
    .frameSyncPolarity = kSAI_PolarityActiveLow,
    .frameSyncEarly = true,
  .syncMode = kSAI_ModeAsync,
  .channelMask = kSAI_Channel0Mask,
  .startChannel = 0U,
  .endChannel = 0U,
  .channelNums = 1U,
  .serialData = {
    .dataWord0Length = (uint8_t)kSAI_WordWidth16bits,
    .dataWordNLength = (uint8_t)kSAI_WordWidth16bits,
    .dataWordLength = (uint8_t)kSAI_WordWidth16bits,
    .dataOrder = kSAI_DataMSB,
    .dataFirstBitShifted = 16U,
    .dataWordNum = 2U,
    .dataMaskedWord = 0x0U
  .fifo = {
    .fifoPacking = kSAI_FifoPackingDisabled,
    .fifoContinueOneError = false
/* I2S0 Rx configuration */
sai_transceiver_t I2S0_Rx_config = {
  .bitClock = {
  .frameSync = {
  .startChannel = 0U,
  .endChannel = 0U,
  .channelNums = 1U,
  .serialData = {
    .dataWordNum = 2U,
  .fifo = {
sai_master_clock_t I2S0_MCLK_config = {
  .mclkOutputEnable = false,
  .mclkSource = kSAI_MclkSourceSysclk,
  .mclkSourceClkHz = I2S0_MCLK_SOURCE_CLOCK_HZ,
  .mclkHz = I2S0_USER_MCLK_HZ
dma_handle_t dmaTxHandle;
dma_handle_t dmaRxHandle;
sai_dma_handle_t g_m_tx_dma_handle;
sai_dma_handle_t g_m_rx_dma_handle;
static void I2S0_init(void) {
  /* Set the source kDmaRequestMux0I2S0Tx request in the DMAMUX */
  DMAMUX_SetSource(I2S0_TX_DMAMUX_BASEADDR, I2S0_TX_DMA_CHANNEL, I2S0_TX_DMA_REQUEST);
  /* Enable the channel 1 in the DMAMUX */
  DMAMUX_EnableChannel(I2S0_TX_DMAMUX_BASEADDR, I2S0_TX_DMA_CHANNEL);
  /* Set the source kDmaRequestMux0I2S0Rx request in the DMAMUX */
  DMAMUX_SetSource(I2S0_RX_DMAMUX_BASEADDR, I2S0_RX_DMA_CHANNEL, I2S0_RX_DMA_REQUEST);
  /* Enable the channel 0 in the DMAMUX */
  DMAMUX_EnableChannel(I2S0_RX_DMAMUX_BASEADDR, I2S0_RX_DMA_CHANNEL);
  /* Create the DMA dmaTxHandle handle */
  DMA_CreateHandle(&dmaTxHandle, I2S0_TX_DMA_BASEADDR, I2S0_TX_DMA_CHANNEL);
  /* Create the DMA dmaRxHandle handle */
  DMA_CreateHandle(&dmaRxHandle, I2S0_RX_DMA_BASEADDR, I2S0_RX_DMA_CHANNEL);
  /* Initialize SAI clock gate */
  SAI_Init(I2S0_PERIPHERAL);
  /* Create the SAI Tx DMA handle */
  SAI_TransferTxCreateHandleDMA(I2S0_PERIPHERAL, &g_m_tx_dma_handle, AudioBufferHandler_DMATxCallback, NULL, &dmaTxHandle);
  /* Create the SAI Rx DMA handle */
  SAI_TransferRxCreateHandleDMA(I2S0_PERIPHERAL, &g_m_rx_dma_handle, AudioBufferHandler_DMARxCallback, NULL, &dmaRxHandle);
  /* Configures SAI Tx sub-module functionality */
  SAI_TransferTxSetConfigDMA(I2S0_PERIPHERAL, &g_m_tx_dma_handle, &I2S0_Tx_config);
  /* Configures SAI Rx sub-module functionality */
  SAI_TransferRxSetConfigDMA(I2S0_PERIPHERAL, &g_m_rx_dma_handle, &I2S0_Rx_config);
  /* Initialize SAI master clock */
  SAI_SetMasterClockConfig(I2S0_PERIPHERAL, &I2S0_MCLK_config);
 * Initialization functions
void BOARD_InitPeripherals(void)
  /* Global initialization */
  DMAMUX_Init(DMA_DMAMUX_BASEADDR);
  DMA_Init(DMA_DMA_BASEADDR);
  /* Initialize components */
  I2S0_init();
I was able to get audio playback and recording with the old code but with the IDE-generated SAI configuration I don't seem to be getting any playback and the record line seems to just be recording white noise.
Any advice would be greatly appreciated
1,007件の閲覧回数
Pavel_Hernandez
In order to help you, Could you tell me if you are based on an example? if yes what kind the example or documentation are you based on?
Pavel
