I want to use IMX RT1052 FLEXIO in parallel transmit mode.
According to the iMX RT1050 Processor Reference Manual, RT1052 FLEXIO supports parallel shift mode (4, 8, 16, 32 bits), but I can not configure FLEXIO to parallel transmit mode with MCUXpresso SDK 2.3.0.
I found there is no FLEXIO feature definition (including FSL_FEATURE_FLEXIO_HAS_PARALLEL_WIDTH ) in i.MX RT1052 chip feature definition file MIMXRT1052_features.h.
Is the FLEXIO feature disabed in RT1052, or is it just a BUG in SDK 2.3.0?
已解决! 转到解答。
Hi James,
No, it is not. But FSL_FEATURE_FLEXIO_HAS_PARALLEL_WIDTH was not defined in SDK2.3.0. you can define it by yourself , it can also be normally used.
The feature will be added to subsequent SDK.
Rita
Hi James,
Rita
