Unable to import Bluetooth middleware and frame work
NITHIN_ABHIMANUE
I am new to MCUXpresso SDK and trying to bring a Bluetooth characteristics on FRDM-KW36.
As per tutorial i have downloaded SDK v2.2.9 from https://mcuxpresso.nxp.com/en/dashboard?uvid=402984&to_vault=true# .
I was taken heart rate sensor example and was trying to import that example using MCUEXPRESSO.
And the folder structure is as below
I was able to compile this and this is working as intended.
But when i am creating a new project, i am not able to select a middleware, as you see
Middleware and the packages i am looking for here is missing(Bluetooth related).
Am i missing any steps? Should I import all the middleware manually?
Please guide me some reference here.
Thanks in advance
Nithin Abhimanue
Ricardo_Zamora
Hi Nithin,
Hope you are doing well. You can add the Bluetooth folders manually, but if you want to create a project with BLE, the recommendations it to take as a base one of the BLE examples, do your modifications and add other drivers if needed.
Ricardo
