Hi Sir,
When I was evaluating the LPC54628 development board , I met an issue .
Example : SDK\LPC54628J512\boards\lpcxpresso54628\usb_examples\usb_device_hid_generic
Evaluation Board : LPCXpresso54628
NXP Original Example : USB HID receive data , then send data directly.
Default USB package length = 8 bytes
This example could run well and PC send bytes(less than 8 bytes) to USB HID, then USB HID reply these bytes to PC directly.
I tried to modify data length large than 8 (e.g. 64), but set point at USB_Devicehid irq, see g_UsbDeviceHidGeneric.buffer[ ] size still is 8 bytes.
I believe it should be modified other code, hope your suggestion ASAP.
BTW : I think that user should not modify other layer code except some Marco Definition and user self-definition command while USB recognize.
Thanks.
Vincent
Hi Vincent,
I checked you submitted the same question at case: 00187393.
Please check my reply at that case.
I suggest to follow the [readme.pdf] file to make related modification at PC test tool Wimar’s USB HID Component.
The [readme.pdf] located at below path:
..\SDK_2.4.1_LPCXpresso54628\boards\lpcxpresso54608\usb_examples\usb_device_hid_generic\bm
Wish it helps.
Mike
