The BUBBLE example in SDK_2.2_FRDM-K64F issue?
1,954 次查看
guoshengw
I just build SDK_2.2_FRDM-K64F and run bubble  demo (SDK_2.2_FRDM-K64F\boards\frdmk64f\demo_apps\bubble), I can see Print out the raw accelerometer data in PUTTY, but RGB LED is always OFF when change angles of board.
Is it the issue of the new version SDK? I can run bubble demo in SDK_2.0_FRDM-K64F without any problem.
1,678 次查看
Jonathan_Iglesias
Dear guosheng wang
Thank you for your feedback, I checked the example and the LED did  turn on, please send me more information,  such as screenshots or  try to download again the SDK.
Best regards.
Jonathan
1,678 次查看
guoshengw
Dear Jonathan
Thanks for your replying, and I add such code can work normally.
LED_RED_INIT(1);
LED_GREEN_INIT(1);
Guosheng
