Hi Folks,
I have inherited a project which references specifically version SDK_2.2.1_MKL27Z256xxx4.zip
I can only install version 2.7.0 from the SDK builder - there is no apparent archive for older versions.
Can someone please kindly provide a link or attachment to SDK_2.2.1_MKL27Z256xxx4.zip
The attached picure shows the (default) configuration required (except version 2.2.1 is sought not 2.7.0).
Many thanks.
Solved! Go to Solution.
This may because I include everything into the package.
jing
Hi Rob,
I've put this package in google drive.
https://drive.google.com/open?id=11EvRxEZZuB0kqWgydqJrgIrt7qHgc9SC
Jing
Hi Jing,
Much appreciated, thank you. It downloaded sucessfully.
Interestingly
size of the 2.2.1 zip is 89MB approx
size of the 2.7.0 zip is 16MB approx
Stay safe
Rob
jing
