RT1170 EVK app won't run on an EVKB
Littell
Even the dead-simple iled_blinky demo app built with the EVK SDK won't load and run on an EVKB.  Why?
And most importantly, how can I re-target apps build with the EVK SDK to the EVKB SDK.
Thanks very much.
kerryzhou
Hi @Littell ,
Thanks you for your updated information.
If you want to use the SPT or other tools, you neet to use these steps:
1. Board enter the serial download mode
SW1:1-OFF,2-OFF,3-OFF,4-ON
SW2:0000000000
2. Find another USB cable to connect the J20, then you can use the mcubootutility to connect it
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v6.2.0
the related user manual is:
This is the connection result:
You can find it is connected, please also try it on your side.
Then mass erase use this one:
Please try it on your side.
If yu still have issues, you may need to check, whether your board have issues or not, or you modify the fuse bit or not.
kerry
Littell
The SPT was unable to pass even the "Test Connection".
kerryzhou
Hi @Littell ,
SW2:0000000000
kerry
Littell
Thank you VERY much! It seems to be back in business.
Littell
Hi, Kerry!  Thank you for the quick reply.  Unfortunately the IDE Mass Erase resulted in the following error:
Flash Driver V.2 startup failed - rc Ef(34): Timed-out initializing flash.
chip initialization failed - Ef(34): Timed-out initializing flash.
failed to initialize flash driver MIMXRT1170_SFDP_QSPI.cfx
( 65) Chip Setup Complete
(100) Target Operation Failed
Unable to perform operation!
Command failed with exit code 1
I guess I should try the SPT Mass Erase now...
Dave
kerryzhou
Hi @Littell ,
  Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
1. please use the following link to do the mass erase at first:
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/RT-board-recovery-for-debugger-connect-issues/ta...
2. To the MIMXRT1170-EVKB, please download the EVKB related SDK, and import the code from the EVKB SDK:
https://mcuxpresso.nxp.com/en/builder?hw=MIMXRT1170-EVKB
3. About the EVK and EVKB, the used QSPI flash is different, so the XIP FCB have difference.
This is the EVK flexspi_nor_config.c
#define FLASH_DUMMY_CYCLES 0x09
#define FLASH_DUMMY_VALUE  0x09
const flexspi_nor_config_t qspiflash_config = {
    .memConfig =
            .tag              = FLEXSPI_CFG_BLK_TAG,
            .version          = FLEXSPI_CFG_BLK_VERSION,
            .readSampleClksrc=kFlexSPIReadSampleClk_LoopbackFromDqsPad,
            .csHoldTime       = 3u,
            .csSetupTime      = 3u,
            // Enable DDR mode, Wordaddassable, Safe configuration, Differential clock
            .controllerMiscOption = 0x10,
            .deviceType           = kFlexSpiDeviceType_SerialNOR,
            .sflashPadType        = kSerialFlash_4Pads,
            .serialClkFreq        = kFlexSpiSerialClk_133MHz,
            .sflashA1Size         = 16u * 1024u * 1024u,
            /* Enable flash configuration feature */
            .configCmdEnable   = 1u,
            .configModeType[0] = kDeviceConfigCmdType_Generic,
            /* Set configuration command sequences */
            .configCmdSeqs[0] =
                    .seqNum   = 1,
                    .seqId    = 12,
                    .reserved = 0,
            /* Prepare setting value for Read Register in flash */
            .configCmdArgs[0] = (FLASH_DUMMY_VALUE << 3),
            .lookupTable =
                    // Read LUTs
                    [0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEB, RADDR_SDR, FLEXSPI_4PAD, 0x18),
                    [1] = FLEXSPI_LUT_SEQ(DUMMY_SDR, FLEXSPI_4PAD, FLASH_DUMMY_CYCLES, READ_SDR, FLEXSPI_4PAD, 0x04),
                    // Read Status LUTs
                    [4 * 1 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x05, READ_SDR, FLEXSPI_1PAD, 0x04),
                    // Write Enable LUTs
                    [4 * 3 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x06, STOP, FLEXSPI_1PAD, 0x0),
                    // Erase Sector LUTs
                    [4 * 5 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x20, RADDR_SDR, FLEXSPI_1PAD, 0x18),
                    // Erase Block LUTs
                    [4 * 8 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xD8, RADDR_SDR, FLEXSPI_1PAD, 0x18),
                    // Pape Program LUTs
                    [4 * 9 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x02, RADDR_SDR, FLEXSPI_1PAD, 0x18),
                    [4 * 9 + 1] = FLEXSPI_LUT_SEQ(WRITE_SDR, FLEXSPI_1PAD, 0x04, STOP, FLEXSPI_1PAD, 0x0),
                    // Erase Chip LUTs
                    [4 * 11 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x60, STOP, FLEXSPI_1PAD, 0x0),
                    // Set Read Register LUTs
                    [4 * 12 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xC0, WRITE_SDR, FLEXSPI_1PAD, 0x01),
                    [4 * 12 + 1] = FLEXSPI_LUT_SEQ(STOP, FLEXSPI_1PAD, 0x00, 0, 0, 0),
    .pageSize           = 256u,
    .sectorSize         = 4u * 1024u,
    .ipcmdSerialClkFreq = 0x1,
    .blockSize          = 64u * 1024u,
    .isUniformBlockSize = false,
This is the EVKB flexspi_nor_config.c
#define FLASH_DUMMY_CYCLES 0x08
#define FLASH_DUMMY_VALUE  0x03
    .memConfig =
            .csHoldTime       = 3u,
            .csSetupTime      = 3u,
            .sflashA1Size         = 64u * 1024u * 1024u,
            .configCmdSeqs[0] =
                    .seqNum   = 1,
                    .seqId    = 12,
                    .reserved = 0,
            .configCmdArgs[0] = (FLASH_DUMMY_VALUE << 4),
            .lookupTable =
                    // Read LUTs
                    [0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEC, RADDR_SDR, FLEXSPI_4PAD, 0x20),
                    // Read Status LUTs
                    [4 * 5 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x21, RADDR_SDR, FLEXSPI_1PAD, 0x20),
                    // Erase Block LUTs
                    [4 * 9 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x12, RADDR_SDR, FLEXSPI_1PAD, 0x20),
                    // Erase Chip LUTs
    .pageSize           = 256u,
You can see, the LUT, the dummy cycle have difference.
So, if you want to use the EVK demo to download to the EVKB, you need to modify the flexspi_nor_config.c code to the EVKB code.
In fact, I suggest you use the EVKB SDK directly, that will be more easy to you.
Wish it helps you!
If you still have quesiton about it, please kindly let me know.
If your question is solved, please help me to mark the correct answer to this case, just to close it.
Any new issues, welcome to create the new case, thanks.
Kerry
%3CLINGO-SUB%20id%3D%22lingo-sub-1892405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EEven%20the%20dead-simple%20iled_blinky%20demo%20app%20built%20with%20the%20EVK%20SDK%20won't%20load%20and%20run%20on%20an%20EVKB.%26nbsp%3B%20Why%3F%3C%2FP%3E%3CP%3EAnd%20most%20importantly%2C%20how%20can%20I%20re-target%20apps%20build%20with%20the%20EVK%20SDK%20to%20the%20EVKB%20SDK.%3C%2FP%3E%3CP%3EThanks%20very%20much.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1893669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893669%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20VERY%20much!%20It%20seems%20to%20be%20back%20in%20business.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1893232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234959%22%20target%3D%22_blank%22%3E%40Littell%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20you%20for%20your%20updated%20information.%3C%2FP%3E%0A%3CP%3EIf%20you%20want%20to%20use%20the%20SPT%20or%20other%20tools%2C%20you%20neet%20to%20use%20these%20steps%3A%3C%2FP%3E%0A%3CP%3E1.%20Board%20enter%20the%20serial%20download%20mode%3C%2FP%3E%0A%3CP%3ESW1%3A1-OFF%2C2-OFF%2C3-OFF%2C4-ON%3C%2FP%3E%0A%3CP%3ESW2%3A0000000000%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20Find%20another%20USB%20cable%20to%20connect%20the%20J20%2C%20then%20you%20can%20use%20the%20mcubootutility%20to%20connect%20it%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FJayHeng%2FNXP-MCUBootUtility%2Freleases%2Ftag%2Fv6.2.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FJayHeng%2FNXP-MCUBootUtility%2Freleases%2Ftag%2Fv6.2.0%3C%2FA%3E%3CBR%20%2F%3Ethe%20related%20user%20manual%20is%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FJayHeng%2FNXP-MCUBootUtility%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FJayHeng%2FNXP-MCUBootUtility%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThis%20is%20the%20connection%20result%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kerryzhou_0-1719281735626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kerryzhou_0-1719281735626.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F285543i238CA6DA6583FAA9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kerryzhou_0-1719281735626.png%22%20alt%3D%22kerryzhou_0-1719281735626.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EYou%20can%20find%20it%20is%20connected%2C%20please%20also%20try%20it%20on%20your%20side.%3C%2FP%3E%0A%3CP%3EThen%20mass%20erase%20use%20this%20one%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kerryzhou_1-1719281775843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kerryzhou_1-1719281775843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F285544i109FCF86B82307DE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kerryzhou_1-1719281775843.png%22%20alt%3D%22kerryzhou_1-1719281775843.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20try%20it%20on%20your%20side.%3C%2FP%3E%0A%3CP%3EIf%20yu%20still%20have%20issues%2C%20you%20may%20need%20to%20check%2C%20whether%20your%20board%20have%20issues%20or%20not%2C%20or%20you%20modify%20the%20fuse%20bit%20or%20not.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3Ekerry%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1893126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20SPT%20was%20unable%20to%20pass%20even%20the%20%22Test%20Connection%22.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1893100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Kerry!%26nbsp%3B%20Thank%20you%20for%20the%20quick%20reply.%26nbsp%3B%20Unfortunately%20the%20IDE%20Mass%20Erase%20resulted%20in%20the%20following%20error%3A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3EFlash%20Driver%20V.2%20startup%20failed%20-%20rc%20Ef(34)%3A%20Timed-out%20initializing%20flash.%3C%2FP%3E%3CP%3E%3CSPAN%3Echip%20initialization%20failed%20-%20Ef(34)%3A%20Timed-out%20initializing%20flash.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Efailed%20to%20initialize%20flash%20driver%20MIMXRT1170_SFDP_QSPI.cfx%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(%2065)%20Chip%20Setup%20Complete%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E(100)%20Target%20Operation%20Failed%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EUnable%20to%20perform%20operation!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECommand%20failed%20with%20exit%20code%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20guess%20I%20should%20try%20the%20SPT%20Mass%20Erase%20now...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EDave%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1892499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20RT1170%20EVK%20app%20won't%20run%20on%20an%20EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234959%22%20target%3D%22_blank%22%3E%40Littell%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20Thank%20you%20for%20your%20interest%20in%20the%20NXP%20MIMXRT%20product%2C%20I%20would%20like%20to%20provide%20service%20for%20you.%3C%2FP%3E%0A%3CP%3E1.%20please%20use%20the%20following%20link%20to%20do%20the%20mass%20erase%20at%20first%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Knowledge-Base%2FRT-board-recovery-for-debugger-connect-issues%2Fta-p%2F1635260%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Knowledge-Base%2FRT-board-recovery-for-debugger-connect-issues%2Fta-p%2F1635260%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E2.%20To%20the%20MIMXRT1170-EVKB%2C%20please%20download%20the%20EVKB%20related%20SDK%2C%20and%20import%20the%20code%20from%20the%20EVKB%20SDK%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fbuilder%3Fhw%3DMIMXRT1170-EVKB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fbuilder%3Fhw%3DMIMXRT1170-EVKB%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E3.%20About%20the%20EVK%20and%20EVKB%2C%20the%20used%20QSPI%20flash%20is%20different%2C%20so%20the%20XIP%20FCB%20have%20difference.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kerryzhou_1-1719194803993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kerryzhou_1-1719194803993.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F285338iF288D4709B0B9ABE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kerryzhou_1-1719194803993.png%22%20alt%3D%22kerryzhou_1-1719194803993.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kerryzhou_0-1719194797128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kerryzhou_0-1719194797128.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F285337i6D3FE783A419FFB4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kerryzhou_0-1719194797128.png%22%20alt%3D%22kerryzhou_0-1719194797128.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20is%20the%20EVK%20flexspi_nor_config.c%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%23define%20FLASH_DUMMY_CYCLES%200x09%0A%23define%20FLASH_DUMMY_VALUE%20%200x09%0A%0Aconst%20flexspi_nor_config_t%20qspiflash_config%20%3D%20%7B%0A%20%20%20%20.memConfig%20%3D%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20.tag%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20FLEXSPI_CFG_BLK_TAG%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.version%20%20%20%20%20%20%20%20%20%20%3D%20FLEXSPI_CFG_BLK_VERSION%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.readSampleClksrc%3DkFlexSPIReadSampleClk_LoopbackFromDqsPad%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.csHoldTime%20%20%20%20%20%20%20%3D%203u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.csSetupTime%20%20%20%20%20%20%3D%203u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Enable%20DDR%20mode%2C%20Wordaddassable%2C%20Safe%20configuration%2C%20Differential%20clock%0A%20%20%20%20%20%20%20%20%20%20%20%20.controllerMiscOption%20%3D%200x10%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.deviceType%20%20%20%20%20%20%20%20%20%20%20%3D%20kFlexSpiDeviceType_SerialNOR%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.sflashPadType%20%20%20%20%20%20%20%20%3D%20kSerialFlash_4Pads%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.serialClkFreq%20%20%20%20%20%20%20%20%3D%20kFlexSpiSerialClk_133MHz%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.sflashA1Size%20%20%20%20%20%20%20%20%20%3D%2016u%20*%201024u%20*%201024u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Enable%20flash%20configuration%20feature%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdEnable%20%20%20%3D%201u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.configModeType%5B0%5D%20%3D%20kDeviceConfigCmdType_Generic%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Set%20configuration%20command%20sequences%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdSeqs%5B0%5D%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.seqNum%20%20%20%3D%201%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.seqId%20%20%20%20%3D%2012%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.reserved%20%3D%200%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Prepare%20setting%20value%20for%20Read%20Register%20in%20flash%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdArgs%5B0%5D%20%3D%20(FLASH_DUMMY_VALUE%20%26lt%3B%26lt%3B%203)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.lookupTable%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Read%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B0%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xEB%2C%20RADDR_SDR%2C%20FLEXSPI_4PAD%2C%200x18)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B1%5D%20%3D%20FLEXSPI_LUT_SEQ(DUMMY_SDR%2C%20FLEXSPI_4PAD%2C%20FLASH_DUMMY_CYCLES%2C%20READ_SDR%2C%20FLEXSPI_4PAD%2C%200x04)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Read%20Status%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%201%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x05%2C%20READ_SDR%2C%20FLEXSPI_1PAD%2C%200x04)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Write%20Enable%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%203%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x06%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Sector%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%205%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x20%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Block%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%208%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xD8%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Pape%20Program%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%209%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x02%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%209%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(WRITE_SDR%2C%20FLEXSPI_1PAD%2C%200x04%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Chip%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2011%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x60%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Set%20Read%20Register%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2012%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xC0%2C%20WRITE_SDR%2C%20FLEXSPI_1PAD%2C%200x01)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2012%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(STOP%2C%20FLEXSPI_1PAD%2C%200x00%2C%200%2C%200%2C%200)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20.pageSize%20%20%20%20%20%20%20%20%20%20%20%3D%20256u%2C%0A%20%20%20%20.sectorSize%20%20%20%20%20%20%20%20%20%3D%204u%20*%201024u%2C%0A%20%20%20%20.ipcmdSerialClkFreq%20%3D%200x1%2C%0A%20%20%20%20.blockSize%20%20%20%20%20%20%20%20%20%20%3D%2064u%20*%201024u%2C%0A%20%20%20%20.isUniformBlockSize%20%3D%20false%2C%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20is%20the%20EVKB%20flexspi_nor_config.c%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%23define%20FLASH_DUMMY_CYCLES%200x08%0A%23define%20FLASH_DUMMY_VALUE%20%200x03%0A%0Aconst%20flexspi_nor_config_t%20qspiflash_config%20%3D%20%7B%0A%20%20%20%20.memConfig%20%3D%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20.tag%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20FLEXSPI_CFG_BLK_TAG%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.version%20%20%20%20%20%20%20%20%20%20%3D%20FLEXSPI_CFG_BLK_VERSION%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.readSampleClksrc%3DkFlexSPIReadSampleClk_LoopbackFromDqsPad%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.csHoldTime%20%20%20%20%20%20%20%3D%203u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.csSetupTime%20%20%20%20%20%20%3D%203u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Enable%20DDR%20mode%2C%20Wordaddassable%2C%20Safe%20configuration%2C%20Differential%20clock%0A%20%20%20%20%20%20%20%20%20%20%20%20.controllerMiscOption%20%3D%200x10%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.deviceType%20%20%20%20%20%20%20%20%20%20%20%3D%20kFlexSpiDeviceType_SerialNOR%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.sflashPadType%20%20%20%20%20%20%20%20%3D%20kSerialFlash_4Pads%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.serialClkFreq%20%20%20%20%20%20%20%20%3D%20kFlexSpiSerialClk_133MHz%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.sflashA1Size%20%20%20%20%20%20%20%20%20%3D%2064u%20*%201024u%20*%201024u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Enable%20flash%20configuration%20feature%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdEnable%20%20%20%3D%201u%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.configModeType%5B0%5D%20%3D%20kDeviceConfigCmdType_Generic%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Set%20configuration%20command%20sequences%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdSeqs%5B0%5D%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.seqNum%20%20%20%3D%201%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.seqId%20%20%20%20%3D%2012%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20.reserved%20%3D%200%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Prepare%20setting%20value%20for%20Read%20Register%20in%20flash%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20.configCmdArgs%5B0%5D%20%3D%20(FLASH_DUMMY_VALUE%20%26lt%3B%26lt%3B%204)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20.lookupTable%20%3D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Read%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B0%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xEC%2C%20RADDR_SDR%2C%20FLEXSPI_4PAD%2C%200x20)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B1%5D%20%3D%20FLEXSPI_LUT_SEQ(DUMMY_SDR%2C%20FLEXSPI_4PAD%2C%20FLASH_DUMMY_CYCLES%2C%20READ_SDR%2C%20FLEXSPI_4PAD%2C%200x04)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Read%20Status%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%201%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x05%2C%20READ_SDR%2C%20FLEXSPI_1PAD%2C%200x04)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Write%20Enable%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%203%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x06%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Sector%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%205%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x21%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x20)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Block%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%208%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xD8%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Pape%20Program%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%209%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x12%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x20)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%209%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(WRITE_SDR%2C%20FLEXSPI_1PAD%2C%200x04%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Erase%20Chip%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2011%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x60%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F%2F%20Set%20Read%20Register%20LUTs%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2012%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xC0%2C%20WRITE_SDR%2C%20FLEXSPI_1PAD%2C%200x01)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%5B4%20*%2012%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(STOP%2C%20FLEXSPI_1PAD%2C%200x00%2C%200%2C%200%2C%200)%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20%20%20%20%20%7D%2C%0A%20%20%20%20.pageSize%20%20%20%20%20%20%20%20%20%20%20%3D%20256u%2C%0A%20%20%20%20.sectorSize%20%20%20%20%20%20%20%20%20%3D%204u%20*%201024u%2C%0A%20%20%20%20.ipcmdSerialClkFreq%20%3D%200x1%2C%0A%20%20%20%20.blockSize%20%20%20%20%20%20%20%20%20%20%3D%2064u%20*%201024u%2C%0A%20%20%20%20.isUniformBlockSize%20%3D%20false%2C%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EYou%20can%20see%2C%20the%20LUT%2C%20the%20dummy%20cycle%20have%20difference.%3C%2FP%3E%0A%3CP%3ESo%2C%20if%20you%20want%20to%20use%20the%20EVK%20demo%20to%20download%20to%20the%20EVKB%2C%20you%20need%20to%20modify%20the%20flexspi_nor_config.c%20code%20to%20the%20EVKB%20code.%3C%2FP%3E%0A%3CP%3EIn%20fact%2C%20I%20suggest%20you%20use%20the%20EVKB%20SDK%20directly%2C%20that%20will%20be%20more%20easy%20to%20you.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWish%20it%20helps%20you!%3C%2FP%3E%0A%3CP%3EIf%20you%20still%20have%20quesiton%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%3EIf%20your%20question%20is%20solved%2C%20please%20help%20me%20to%20mark%20the%20correct%20answer%20to%20this%20case%2C%20just%20to%20close%20it.%3C%2FP%3E%0A%3CP%3EAny%20new%20issues%2C%20welcome%20to%20create%20the%20new%20case%2C%20thanks.%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3EKerry%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
