Question about removal of three-slot mode for Encrypted XIP in MCUboot
50件の閲覧回数
mastupristi
Senior Contributor I
while testing the MCUboot fork from NXP, I noticed that in the September preview release a useful feature has been removed.
Specifically, I am referring to the support for three-slot mode with Encrypted XIP (two staging slots + one execution slot, used to enable revert).
I saw this commit:
7c455cf2d
with the message:
[MCUX-80671] Encrypted XIP: remove customization for three slot mode
Could you please explain why this functionality was removed?
  • Is it considered deprecated or no longer supported?
  • Are there plans to reintroduce it, or should we adapt our designs to use only two slots in case of encrypted XIP?
  • Was this related to technical limitations, or more to simplify the codebase?
This feature was quite valuable for our use case, and understanding the rationale behind its removal will help us plan the next steps.
Thank you in advance for your clarification.
best regards
Max
タグ(2)
38件の閲覧回数
EdwinHz
Hi @mastupristi,
I will investigate this topic internally. Could you please provide the MCU that you are currently using?
21件の閲覧回数
mastupristi
Hi @EdwinHz
i'm using RT1021
regards
Max
