If I create a new workspace it works. How do I fix it without having to create a new workspace every two weeks? I created this workspace new when I installed 11.6.1 and I've been enduring the default perspective layout and everything for the sake of not deviating any more than necessary from the absolute basics. My one concession has been switching to the dark theme.
Aside from the dark theme selection, I haven't touched any preferences at all. I haven't even changed any view layouts.
To prove it wasn't the dark theme that did it, I switched the new workspace to dark mode and tried again. It prompts for the change, but this is even more disturbing. Check out the attached screenshot. This project was just imported as an SDK example, and then I added the CTIMER driver. In the left pane you can see that I typed some gibberish on line 24. That's the only change I made to the file. You can see in the right pane that what it's trying to import is a completely different version.
Is the SDK management tool importing examples with out-of-date SDK components? Why is it getting different results when the SDK is refreshed?
Where are the SDK tools preferences stored so I can check what's actually there?
Scott
