PWM with multiple period using LPC546xx SCTimer/PWM
3,333 次查看
hemanthvasista
Hello ,
I am using LPC54628(OM13098) development board.
I intent to use PWM output with different period.
Is it possible to have different PWM period in SCT0?
e.g.
SCT0_OUT4      with 50KHz period (+ variable Duty %)
SCT0_OUT6      with 100KHz period (+ variable Duty %)
regards,
Hemanth
标记 (4)
8 回复数
3,110 次查看
Hello  Hemanth S ,
In generally No, we only can set different PWM duty cycle.
Alice
3,110 次查看
hemanthvasista
Hello Alice,
Thanks for your inputs.
Is possible to configure the SCTimer as complimentary pair?
e.g.
SCT0_OUT4  with 100KHz period (+ variable Duty %)
SCT0_OUT6  complimentary output of (SCT0_OUT4)
regards,
Hemanth
3,110 次查看
Hello Hemanth,
Yes, just config output3 and output4 with opposite level.
Recommend you use the MCUXpresso Config to config it:
There are PWM demo under SDK:
Alice
3,110 次查看
hemanthvasista
Hello Alice,
Thanks for the info.
How to set the dead time in SCTimer/PWM?
Is it possible to have complimentary PWM pair in CTimer?
I couldn't get any options.
regards,
Hemanth
3,110 次查看
Hello Hemanth,
You can have a look at the SCTimer cookbook, it includes these demos you mentioned.
https://www.nxp.com/docs/en/application-note/AN11538.zip
Alice
3,110 次查看
hemanthvasista
Hello Alice,
Is complementary PWM with dead time possible from C Timer? The above reference tells mostly about SC Timer.
regards,
Hemanth
3,110 次查看
Hi Hemanth,
No, because  "All single edge controlled PWM outputs go LOW at the beginning of each PWM cycle.
Each PWM output will go HIGH when its match value is reached."
Alice
3,110 次查看
hemanthvasista
Thanks for the info Alice.
regards,
Hemanth
