Motor control examples for PMSM / BLDC and ACIM missing on SDK 2.11.0
ソリューションへジャンプ
2,546件の閲覧回数
MarcoAEE
I am interested in the package "Motor control examples for PMSM / BLDC and ACIM". During the Build of NXP SDK for MKE15Z256xxx7 I am informed that it is present on SDK 2.11.0 (see attached image)
Once installed in MCUXpresso it is not present if you try to import these examples.
With SDK 2.9.0 the sample projects are present.
I hope I was helpful
Thanks for the support
Marco
2,538件の閲覧回数
DanielRuvalcaba
Hello Marco
In this link you can find information about the availability of the motor control SDK.
https://www.nxp.com/design/designs/mcuxpresso-sdk-for-motor-control:MCUXPRESSO-SDK-MOTOR-CONTROL
Referring to this information, the examples for the motor control you are looking for with the KE15Z are available on SDK 2.9.0 only. You will need to consider some development effort to make the examples work in the latest SDK. I’m sorry for the inconvenience this might cause to you.
Best regards, Daniel.
2,539件の閲覧回数
DanielRuvalcaba
Hello Marco
