Yesterday, I set the breakpoint and debug well.
But today, When set breakpoint, 2 strange line symbol is appeared on breakpoint, and can not debug at there. I tried to set breakpoint in OS and driver, but the same problem.
I am using MCUXPresso v11.3.1.
Both LinkServer and Segger are the same problem.
What happens with my debug? and how to solve this?
Thanks for your supports!
Solved! Go to Solution.
It seems that you have disabled breakpoints: see
https://mcuoneclipse.com/2013/02/19/skipping-breakpoints/
I hope this helps,
Erich
I hope this helps,
Erich
