Mcuxpresso can not debug, breakpoint has a strange symbol
anthonyama
Yesterday, I set the breakpoint and debug well.
But today, When set breakpoint, 2 strange line symbol is appeared on breakpoint, and can not debug at there. I tried to set breakpoint in OS and driver, but the same problem.
I am using MCUXPresso v11.3.1.
Both LinkServer and Segger are the same problem.
What happens with my debug? and how to solve this?
Thanks for your supports!
ErichStyger
Senior Contributor V
It seems that you have disabled breakpoints: see
https://mcuoneclipse.com/2013/02/19/skipping-breakpoints/
I hope this helps,
Erich
anthonyama
Hi @ErichStyger
Thanks for your support.
I just disabled it, then debug normally.
ErichStyger
I hope this helps,
Erich
