Hi everybody,
i'm new to MCUXPresso IDE and NXP environment.
I'm developing with MK60FN1M0VLQ15 processor in MCUXPresso IDE, but i can't find the right SDK to start the project. Where can i find it?
150MHz Cortex-M4F MCU, 1MB Flash, 128KB SRAM, Dual USBs (FS + HS), Ethernet, 144-LQFP
Thank you,
Stefano
Solved! Go to Solution.
Hello Stefano,
There is not an SDK for MCUXpresso IDE for this particular part number. As changes on the part includes frequency/clocks and memory there is not an easy way to edit a current SKU.
For this part number the recommendation would using the Kinetis 120MHz and 150Mhz bare metal Sample Code available in the link below (you may need to login to download this file). You may find more details on what’s included on the readme file inside the zip file.
https://www.nxp.com/webapp/sps/download/license.jsp?colCode=KINETIS_120MHZ_SC
My apologies for the inconvenience!
Gustavo
Hello Stefano,
Gustavo
