JN5188 SDK
JN5188 SDK
799 次查看
andrewhartnett
Just created and downloaded the SDK for the JN5188. When I create a project and try to access the peripherals tool it shows as disabled and says 'the tool does not support the selected processor'. Processor shows as JN5188 in the Configuration HW Info, with the Core as Cortex-M$4.
The clock and pins functions both work as expected.
Am I missing something, or is peripheral support not provided in the SDK for the JN5188/89?
Thanks.
784 次查看
EduardoZamora
Hello @andrewhartnett,
Hope you are doing well.
JN5188 may not be supported by Peripherals, TEE and Device Configuration tools. I apologize for any inconvenience this may cause you.
Eduardo.
