Import examples wizard does not show "description" (MCUXpresso IDE 11.8, SDK 2.14.0)
1,066 次查看
danielholala
Senior Contributor II
with earlier MCUXpresso IDE versions (e.g., 11.7.0) and SDKs (eg. 2.13.0), the "import SDK examples" wizard showed a short description for each example, see screenshot:
Now with MCUXpresso IDE V11.8.0 and SDK 2.14.0, the description is empty:
Why is this? Is this a bug or is that observation limited to my installation?
999 次查看
danielholala
Kudos for your response, @RaRo , and I will click "accept as solution" as soon as the issue is resolved.
1,023 次查看
RaRo
Hello @danielholala,
As you mentioned, newest SDK v2.14.0 does not contain short description for the examples. We are letting the team in charge to know about this.
Thank you for the feedback.
Best regards, Raul.
