How to use heap_useNewlib ?
4,573 次查看
jbrud
previously I updated the SDK to Version 2.7 and I noticed the new FreeRTOS heap "heap_useNewlib" implementation. After reading Dave Nadlers blog post(Thanks for that !) and as I use Newlib, I would like to switch. But I wondering how it is meant to use it with MCUXpressoSDK. My first idea was drop in heap_useNewlib.c file and add new number in FreeRTOSConfig.h for example configFRTOS_MEMORY_SCHEME 6.
But this conflicts with NXP's FreeRTOS extension freertos_tasks_c_additions.h which checks configFRTOS_MEMORY_SCHEME > 5  at line 53.  It's clear I could just modify the SDK sources to get it working but that is what I want to avoid. Any advises ?
Additionally there is a uppercase lowercase mistake in heap_useNewlib.c. It tries to inlcude #include "freeRTOS.h"  it should be #include "FreeRTOS.h".
Thanks !
标记 (3)
8 回复数
4,308 次查看
davenadler
Senior Contributor I
j.bruder‌ - Typo fixed and a few other updates on github (you'd need to merge NXP's LD symbols.
configFRTOS_MEMORY_SCHEME does not come into play; do not define it.
Hope that helps,
Best Regards, Dave
4,308 次查看
np
Hi Johannes,
The heap_newlib thing has its roots in Dave Nadler's page here: newlib and FreeRTOS  I'd recommend reading this to understand why using NXP's heap_newlib() is probably a good idea.
There's a comment here (from July 2020) that may answer your issue: https://mcuoneclipse.com/2020/05/31/tutorial-adding-freertos-to-where-there-is-no-freertos/#comment-...
Cheers, Nick
4,308 次查看
jbrud
Any news here ?
4,308 次查看
danielchen
From what I know, this issue will be fixed  in version sdk 2.9, since this fix will be involved with IDE team and FreeRTOS team.
4,307 次查看
jbrud
@NXP Any feedback here ?
4,308 次查看
danielchen
Thanks Johannes , there seems an issue here. Let me consult with develop and let you know the results.
4,308 次查看
Pavel
It looks like your SDK is not SDK for PowerPC or Layerscape processors.
NXP offers Yocto Linux BSP SDK 2.7 for PowerPC or Layerscape processors.
https://source.codeaurora.org/external/qoriq/qoriq-components/yocto-sdk/about/
Pavel Chubakov
4,308 次查看
jbrud
I'm working on a MK64F12, which is a ARM Cortex-M4 and the SDK is generated by NXP's MCUXpresso SDK Builder.
What do you mean ?
