How to route USB devices from FS port HS port
nehadad
I'm using MCX EV5 evaluation board and want to route all the devices that connected to the FS USB port to the HS USB.
I mean, the HS USB is connected to my pc running Windows OS. When I connect USB device to the FS port, I want that the enumeration will be done on the Windows.
I know that I can implement the EVK to be USB host in FS port and USB device in HS port, but I want to pass the data regardless the class ID or any enumeration in the EVK code.
Is there such a possibility? Are there any code samples I can use?
Thanks!
