I found OM4006(LPC54018) has a non-standard SWD interface. I can't connect J-Link to OM4006.
J-Link has a 20 pin interface, OM40006 has a 10 pin mini interface.
Do you have any suggestion about how to connect it? Or do you know how to by an adapter about it?
Jlink to has 20pin interface which can not connect OM40006 board.
You need use a Jtag 20 pin to SWD 10 pin adapter/converter to adapt them.
Actually, OM40006 J7 interface can be used to debug the LPC54018 well. I suggest you using it as debug interface.
Jun Zhang
